hi
will it be possible to add manual irq selection to ros like in windows so we can select the irq for the card in the x86 machines
its support in v5 beta5
thanks but how do you change the irq
we have now seen that r5h can share the same irq and work properly
we have also seen that r52hn can not share an irq with another card
does anybody have a solution for this problem
IRQ are assigned by BIOS afaik - try to change some settings there
i understand but why does the r52 and r5h share irq and work with no problems but when the r52hn share irq with another card the routeros reboot and must be reset by switching off the power
try to put them in different PCI clot and try to disable onboard features that you do not use (like soundcard)
In modern systems/bioses the operating system may overcome most of bios features .
the problem is the r52hn cards dont want to share irq with another card
