I thappened again with 6.49, first it start disconnecting devices, telling there is a low signal.. but it looks the device was in the same place. It There are 3 CAPs there, DOM1 and DOM2 are close each other, different rooms, anyway signal is not lowering down less than -80/-85 inside home, this is why I’ve created an access list kicking out clients with less than -82, and it works.. but it becomes a day.. or better say a situation (all caps including capsman rebooting daily at 6AM) where the Capsman got really confused, a reboot of just it solve the situation, this is why I believe it’s a capsman BUG. Unfortunately I haven’t saved the logs of CAPs and the router today rebooted already, but last time there wasn’t any logs during the foulty events.
The problem starts when I removed the autentication, I’ve created another profile with no password and pointed it in all configurations of caps, the caps rejoined and maybe from that time problem started. Client said me there are troubles with disconnection, I was at work with really few time, I’ve decided then to disable all the access list and let him keep connection at any level, but the problem still
Here you see the device connecting to SAD (the farest CAPS, ignoring there is a DOM1 near too), the strange thing here are 2:
- there are no access list kick outs, so I can think the device decided to connect elsewhere because DOM1 and DOM2 disappeared probably.
- There are no entries about “deregistering device because it connects to another cap”, that should be when the device is moving itself.
Before reboot router I’ve dumped the log on Cpasman, I hope it will be interesting to debug:
# oct/20/2021 19:19: 7 by RouterOS 6.49
# software id = 11RE-K5D6
11:08:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
11:08:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -78
11:08:23 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -85, signal strength -85
11:08:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
11:08:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -82
11:08:43 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -77
11:08:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:08:57 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -70
11:09:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
11:09:19 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:09:21 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
11:09:24 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
11:09:27 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:09:32 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
11:09:38 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -92, signal strength -92
11:11:12 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -76
11:11:42 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:11:42 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -87
11:11:45 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:11:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
11:11:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
11:11:56 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
11:12:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
11:12:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -85
11:12:57 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:12:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -82
11:13:01 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:13:34 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -76
11:13:40 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:13:43 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -78
11:15:40 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
11:15:42 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -77
11:16:09 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz rejected, forbidden by access-list
11:17:18 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
11:17:18 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -54
11:17:42 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, too weak signal, signal strength -88, signal strength -88
11:17:45 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
11:17:48 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -79
11:18:09 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -85, signal strength -85
11:18:54 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
11:18:54 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -87
11:18:57 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
11:19:02 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
11:19:02 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -81
11:19:11 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
11:19:12 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
11:19:12 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 rejected, forbidden by access-list
11:19:17 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -87
11:19:20 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
11:53:33 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -76
11:53:45 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
11:53:45 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 rejected, forbidden by access-list
11:53:45 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
11:53:50 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -78
11:54:48 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, extensive data loss, signal strength -86
11:54:58 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -78
11:55:10 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -83
11:55:19 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
11:55:31 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
11:55:39 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -64
11:55:54 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -85
11:56:03 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, too weak signal, signal strength -92, signal strength -92
11:56:30 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -88, signal strength -88
11:56:30 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -69
11:57:06 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
11:57:41 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
11:57:41 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -80
12:00:12 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -59
12:00:52 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -47
12:00:52 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, registered to other interface, signal strength -73
12:01:25 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
12:01:55 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -34
12:02:27 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz connected, signal strength -59
12:03:11 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -48
12:03:11 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, registered to other interface, signal strength -86
12:03:26 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -29
12:03:26 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, registered to other interface, signal strength -60
12:03:33 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz disconnected, too weak signal, signal strength -76, signal strength -76
12:03:39 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz connected, signal strength -73
12:03:45 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz disconnected, too weak signal, signal strength -75, signal strength -75
12:03:51 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -65
12:07:26 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -57
12:07:26 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, registered to other interface, signal strength -72
12:08:09 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -46
12:08:09 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -75
12:08:23 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -53
12:08:23 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, registered to other interface, signal strength -73
12:09:52 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -54
12:09:52 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -75
12:11:49 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -39
12:11:49 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, registered to other interface, signal strength -34
12:12:09 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -67
12:12:09 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -65
12:12:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -63
12:12:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -76
12:12:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -83, signal strength -83
12:12:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -80
12:12:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -83, signal strength -83
12:12:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
12:12:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -50
12:13:57 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -41
12:13:57 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -77
12:14:19 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -49
12:14:19 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -75
12:14:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -58
12:14:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -65
12:15:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -48
12:15:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -78
12:15:56 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -86, signal strength -86
12:15:57 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -61
12:16:21 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -58
12:16:21 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
12:17:25 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -52
12:17:25 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, registered to other interface, signal strength -68
12:18:06 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -86, signal strength -86
12:18:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -47
12:18:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -43
12:18:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -39
12:21:11 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -84, signal strength -84
12:21:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -53
12:27:06 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, received disassoc: sending station leaving (8), signal strength -44
12:27:08 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz connected, signal strength -47
12:27:18 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz disconnected, received disassoc: sending station leaving (8), signal strength -46
12:27:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -42
12:27:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -90, signal strength -90
12:27:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -47
12:28:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -44
12:28:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -76
12:28:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -47
12:28:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
12:29:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -50
12:29:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -74
12:29:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -32
12:29:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -75
12:29:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -50
12:29:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -73
12:32:31 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -57
12:32:31 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -74
12:32:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -41
12:32:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -74
12:32:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -39
12:33:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -77
12:34:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -56
12:34:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -76
12:35:10 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -55
12:35:10 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
12:36:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -50
12:36:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -76
12:38:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -86, signal strength -86
12:38:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -68
12:38:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -81, signal strength -81
12:38:39 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -52
12:40:27 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -63
12:40:27 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -73
12:41:38 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
12:41:38 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
12:41:38 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
12:41:38 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -36
12:41:38 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 connected, signal strength -38
12:41:38 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM1 disconnected, registered to other interface, signal strength -57
12:41:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -37
12:41:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -78
12:45:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -84, signal strength -84
12:45:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -80
12:45:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -52
12:45:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -80
12:49:19 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -34
12:49:19 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -74
12:49:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -40
12:49:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -48
12:51:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -39
12:51:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -55
12:52:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -47
12:52:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -68
12:58:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -60
12:58:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
12:59:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -41
12:59:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -69
13:00:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -91, signal strength -91
13:01:01 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:01:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:01:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:01:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:01:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:01:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:01:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:01:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:01:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:03:02 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -85, signal strength -85
13:03:02 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
13:03:02 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -75
13:03:05 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, too weak signal, signal strength -88, signal strength -88
13:03:08 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -77
13:03:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -72
13:03:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
13:03:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -73
13:04:14 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
13:04:20 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -71
13:04:26 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, too weak signal, signal strength -81, signal strength -81
13:04:28 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -68
13:04:32 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
13:04:32 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
13:04:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
13:04:36 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -70
13:04:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -87, signal strength -87
13:04:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -81
13:04:49 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
13:04:50 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -84
13:05:57 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
13:06:00 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -86
13:06:26 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
13:06:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -71
13:06:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
13:06:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -84
13:06:48 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
13:06:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
13:06:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -85
13:06:52 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -47
13:06:53 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
13:06:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -86
13:06:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
13:08:01 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz connected, signal strength -63
13:08:04 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz disconnected, too weak signal, signal strength -79, signal strength -79
13:11:34 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -73
13:11:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -84, signal strength -84
13:11:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:11:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:11:52 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -78
13:11:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
13:11:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:11:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:12:11 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
13:12:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -86, signal strength -86
13:12:17 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -77
13:12:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
13:12:40 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -78
13:12:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
13:12:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -69
13:12:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -88, signal strength -88
13:12:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -81
13:13:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -68
13:13:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, registered to other interface, signal strength -84
13:13:45 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -84, signal strength -84
13:13:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:13:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 rejected, forbidden by access-list
13:14:01 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz rejected, forbidden by access-list
13:14:01 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz rejected, forbidden by access-list
13:14:14 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz rejected, forbidden by access-list
13:14:14 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz rejected, forbidden by access-list
13:20:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -47
13:21:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -42
13:21:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -75
13:21:26 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -47
13:21:26 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -58
13:25:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
13:25:22 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -68
13:28:34 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -40
13:28:34 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -62
13:30:51 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -66
13:30:51 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
13:31:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
13:31:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 rejected, forbidden by access-list
13:31:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
13:32:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -77
13:32:53 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -64
13:32:53 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, registered to other interface, signal strength -83
13:33:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -42
13:33:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -70
13:39:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -55
13:39:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -66
13:41:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -41
13:41:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -65
13:48:09 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -45
13:48:09 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -66
13:49:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -35
13:49:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -69
13:51:02 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
13:51:02 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -36
13:51:02 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
13:51:02 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -55
13:51:02 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 reassociating
13:51:02 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 connected, signal strength -39
13:51:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
13:51:32 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -69
13:52:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -41
13:52:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -63
13:52:44 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -77
13:52:44 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -49
13:52:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -46
13:52:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -77
13:57:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -77
13:57:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -72
13:59:27 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
13:59:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
13:59:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -63
13:59:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -57
14:01:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -40
14:01:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -72
14:02:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -46
14:02:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -44
14:02:56 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
14:02:57 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -76
14:03:00 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
14:03:30 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -66
14:03:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -36
14:03:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -43
14:04:03 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, too weak signal, signal strength -82, signal strength -82
14:04:12 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -48
14:09:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -52
14:09:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -72
14:09:37 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -50
14:09:37 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
14:10:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -86, signal strength -86
14:10:03 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -43
14:10:03 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, registered to other interface, signal strength -66
14:10:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -51
14:14:51 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -89, signal strength -89
14:14:51 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -83
14:15:18 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
14:15:19 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
14:18:50 system,info,account user admin logged in from 89.113.47.239 via winbox
14:19:29 system,info item added by admin
14:19:47 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, interface disabled, signal strength -52
14:19:47 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 disconnected, interface disabled, signal strength -54
14:19:47 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 disconnected, interface disabled, signal strength -38
14:19:47 caps,info MikroTik-DOM1: selected channel 2457/20/gn(30dBm) (fixed)
14:19:47 system,info item changed by admin
14:19:49 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -36
14:19:50 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
14:19:50 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
14:19:51 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
14:19:52 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
14:19:53 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, interface disabled, signal strength -55
14:19:53 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 disconnected, interface disabled, signal strength -40
14:19:53 caps,info MikroTik-DOM2: selected channel 2422/20/gn(30dBm) (fixed)
14:19:53 system,info item changed by admin
14:19:55 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 connected, signal strength -40
14:19:57 caps,info FC:F5:C4:82:D9:CE@MikroTik-DOM2 connected, signal strength -37
14:20:01 caps,info MikroTik-SAD-1: selected channel 2437/20/gn(30dBm) (fixed)
14:20:01 system,info item changed by admin
14:20:02 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz connected, signal strength -51
14:20:07 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz disconnected, interface disabled, signal strength -53
14:20:07 system,info item changed by admin
14:20:11 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz connected, signal strength -51
14:20:12 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz disconnected, interface disabled, signal strength -54
14:20:12 system,info item changed by admin
14:20:12 caps,info MikroTik-DOM1-5GHz: selected channel 5200/20-eCee/ac/P(23dBm)
14:20:18 caps,info MikroTik-DOM2-5GHz: selected channel 5260/20-Ceee/ac/DP(20dBm)
14:24:10 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -37
14:24:41 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, received disassoc: sending station leaving (8), signal strength -59
14:24:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -53
14:29:58 system,info,account user admin logged out from 89.113.47.239 via winbox
14:30:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -42
14:30:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -71
14:36:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -82, signal strength -82
14:36:10 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -43
14:37:30 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -51
14:37:30 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -80
14:39:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -36
14:39:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -58
14:39:39 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -84, signal strength -84
14:39:44 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -76
14:40:23 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
14:40:29 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -78
14:40:32 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
14:40:33 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -82
14:41:36 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -68
14:41:36 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, registered to other interface, signal strength -79
14:42:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -52
14:42:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -54
14:42:54 caps,info FC:F5:C4:82:D9:CE@MikroTik-DOM2 disconnected, extensive data loss, signal strength -38
14:43:10 caps,info FC:F5:C4:82:D9:CE@MikroTik-DOM2 connected, signal strength -37
14:44:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -62
14:44:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -72
14:44:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -43
14:44:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -68
14:47:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -73
14:47:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -66
14:47:40 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -44
14:47:40 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -68
14:50:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -54
14:50:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -59
14:50:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -55
14:50:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -67
14:51:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -50
14:51:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -71
14:51:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -52
14:51:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -62
14:51:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -81, signal strength -81
14:52:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -62
14:52:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -58
14:52:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -75
14:53:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -57
14:53:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -72
14:53:28 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -58
14:53:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -52
14:53:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -74
14:53:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -57
14:53:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -63
14:54:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -35
14:54:16 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -76
14:54:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -53
14:54:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -63
14:54:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -44
14:54:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -76
14:55:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -57
14:55:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -66
14:56:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -43
14:56:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -74
14:56:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -56
14:56:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -65
15:00:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -41
15:00:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -79
15:00:15 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -58
15:00:15 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -70
15:01:06 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -42
15:01:06 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -77
15:01:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -50
15:01:18 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -68
15:01:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -42
15:01:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -74
15:02:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -84, signal strength -84
15:02:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -78
15:02:31 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, too weak signal, signal strength -82, signal strength -82
15:02:33 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -66
15:03:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
15:03:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -50
15:06:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -63
15:06:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -76
15:06:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -50
15:06:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -69
15:13:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -57
15:13:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -63
15:13:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -46
15:13:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -45
15:14:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -53
15:14:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -68
15:14:30 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -46
15:14:30 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -70
15:14:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -53
15:14:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -64
15:15:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -45
15:15:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -59
15:15:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -56
15:15:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -57
15:15:36 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -51
15:15:36 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -72
15:16:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -67
15:16:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -71
15:17:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -49
15:17:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -72
15:18:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -36
15:18:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -62
15:19:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -52
15:19:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -38
15:19:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -41
15:19:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -59
15:27:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -44
15:27:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
15:29:04 interface,info ether2-DOM2 link down
15:29:29 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, interface disabled, signal strength -62
15:29:29 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, interface disabled, signal strength -62
15:29:29 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 disconnected, interface disabled, signal strength -53
15:29:29 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 disconnected, interface disabled, signal strength -38
15:29:29 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 disconnected, interface disabled, signal strength -41
15:29:29 caps,info FC:F5:C4:82:D9:CE@MikroTik-DOM2 disconnected, interface disabled, signal strength -37
15:30:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -85
15:30:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:30:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
15:30:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
15:30:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -84
15:31:17 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:31:17 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -86
15:31:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:31:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
15:31:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
15:31:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
15:32:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, extensive data loss, signal strength -87
15:32:09 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
15:32:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
15:33:45 interface,info ether2-DOM2 link up (speed 1G, full duplex)
15:34:04 interface,info ether2-DOM2 link down
15:35:39 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -87
15:35:42 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:36:43 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
15:37:10 interface,info ether2-DOM2 link up (speed 1G, full duplex)
15:37:16 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:37:18 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -85
15:37:27 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:37:28 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
15:37:34 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:37:38 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -85
15:37:41 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:37:41 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
15:37:44 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:37:44 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
15:37:46 interface,info ether2-DOM2 link down
15:37:47 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
15:37:50 interface,info ether2-DOM2 link up (speed 1G, full duplex)
15:37:58 caps,info [::ffff:192.168.88.2:49475,Join,[2C:C8:1B:22:81:DD]] joined, provides radio(s): 2C:C8:1B:22:81:E2,2C:C8:1B:22:81:E3
15:37:59 caps,info MikroTik-DOM1: selected channel 2457/20/gn(30dBm) (fixed)
15:37:59 caps,info [::ffff:192.168.88.4:53486,Join,[2C:C8:1B:50:49:32]] joined, provides radio(s): 2C:C8:1B:50:49:37,2C:C8:1B:50:49:38
15:37:59 caps,info MikroTik-DOM2: selected channel 2422/20/gn(30dBm) (fixed)
15:38:00 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:38:01 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 connected, signal strength -39
15:38:03 caps,info MikroTik-DOM1-5GHz: selected channel 5200/20-eCee/ac/P(23dBm)
15:38:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -56
15:38:09 caps,info MikroTik-DOM2-5GHz: selected channel 5260/20-Ceee/ac/DP(20dBm)
15:38:15 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:38:15 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -58
15:38:21 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:38:21 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:38:23 caps,info FC:F5:C4:82:D9:CE@MikroTik-DOM2 connected, signal strength -35
15:38:35 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:38:35 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -37
15:38:46 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:38:46 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:38:58 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 disconnected, received disassoc: sending station leaving (8), signal strength -38
15:39:00 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:39:05 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:39:05 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -55
15:39:30 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:39:30 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:39:33 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:39:33 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -37
15:40:03 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 disconnected, received disassoc: sending station leaving (8), signal strength -54
15:40:07 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:40:07 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -36
15:40:20 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:40:32 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -63
15:40:45 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:40:45 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:40:45 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:40:45 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:40:56 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -48
15:40:57 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 reassociating
15:40:57 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -49
15:41:09 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 connected, signal strength -47
15:41:22 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:41:22 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:41:23 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -85
15:41:23 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, registered to other interface, signal strength -53
15:41:29 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:41:29 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -85
15:41:43 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:41:43 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -37
15:41:47 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:41:53 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
15:41:55 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:41:55 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:41:59 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:41:59 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
15:42:14 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
15:42:21 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:42:21 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
15:42:56 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:42:56 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
15:42:56 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:42:56 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:44:21 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:44:21 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -37
15:44:36 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz connected, signal strength -53
15:44:37 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM1 disconnected, received disassoc: sending station leaving (8), signal strength -52
15:44:37 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -87
15:44:43 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
15:44:43 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 rejected, forbidden by access-list
15:44:43 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -77
15:44:46 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -86, signal strength -86
15:44:49 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -79
15:45:22 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -84, signal strength -84
15:45:25 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -77
15:45:27 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz disconnected, too weak signal, signal strength -84, signal strength -84
15:45:27 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz connected, signal strength -42
15:46:00 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz disconnected, too weak signal, signal strength -83, signal strength -83
15:46:00 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz connected, signal strength -51
15:46:04 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
15:46:04 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -79
15:46:07 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
15:46:08 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
15:46:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:46:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:46:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:46:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:46:14 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
15:46:14 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -78
15:46:15 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz disconnected, too weak signal, signal strength -90, signal strength -90
15:46:17 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz connected, signal strength -58
15:46:23 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
15:47:10 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:47:10 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
15:48:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:48:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:48:22 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:48:23 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -70
15:48:26 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:48:31 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:48:32 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 reassociating
15:48:32 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -70
15:48:41 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:48:53 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:48:56 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:48:58 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, received deauth: unspecified (1), signal strength -67
15:49:02 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:49:06 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -74
15:49:08 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:49:08 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -37
15:49:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:49:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:51:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:51:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:51:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
15:51:26 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -78
15:51:53 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz connected, signal strength -54
15:51:53 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz disconnected, registered to other interface, signal strength -53
15:52:01 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz connected, signal strength -46
15:52:01 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz disconnected, registered to other interface, signal strength -53
15:52:10 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:52:10 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:54:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:54:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:54:33 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 disconnected, received disassoc: sending station leaving (8), signal strength -45
15:55:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:55:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:55:37 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 connected, signal strength -42
15:56:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:56:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
15:56:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:56:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:57:11 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:57:11 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:57:48 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -85, signal strength -85
15:57:51 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:57:54 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:57:55 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:58:00 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:58:05 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:58:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:58:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:58:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
15:58:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
15:58:15 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -75
15:58:18 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
15:58:20 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:58:24 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:58:28 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:58:33 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
15:58:42 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -69
15:58:45 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 disconnected, received disassoc: sending station leaving (8), signal strength -39
15:58:46 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz disconnected, too weak signal, signal strength -76, signal strength -76
15:58:46 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz connected, signal strength -66
15:59:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
15:59:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
15:59:09 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
16:00:05 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
16:00:05 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
16:00:07 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
16:00:07 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
16:00:10 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz disconnected, too weak signal, signal strength -76, signal strength -76
16:00:19 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz rejected, forbidden by access-list
16:00:19 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz rejected, forbidden by access-list
16:00:21 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz rejected, forbidden by access-list
16:00:21 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz rejected, forbidden by access-list
16:00:22 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM2-5GHz rejected, forbidden by access-list
16:00:22 caps,info 7A:40:62:73:A1:C8@MikroTik-DOM1-5GHz rejected, forbidden by access-list
16:00:22 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 connected, signal strength -57
16:02:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
16:02:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
16:03:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -88, signal strength -88
16:03:55 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 disconnected, too weak signal, signal strength -90, signal strength -90
16:03:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:03:57 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:03:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:03:59 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
16:04:02 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
16:04:26 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:04:34 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:04:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:05:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
16:05:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
16:05:22 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
16:05:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -85, signal strength -85
16:05:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:05:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:05:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -81
16:05:29 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
16:05:29 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
16:05:42 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 connected, signal strength -77
16:06:03 caps,info 5E:9F:3D:BE:CF:94@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
16:06:10 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
16:06:10 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
16:06:17 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
16:06:19 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
16:06:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:06:25 caps,info 5E:9F:3D:BE:CF:94@MikroTik-DOM2 rejected, forbidden by access-list
16:06:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -86
16:06:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
16:06:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 rejected, forbidden by access-list
16:07:13 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
16:07:13 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
16:07:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -62
16:08:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
16:08:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
16:09:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
16:09:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
16:09:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:09:15 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -71
16:10:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
16:10:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:12:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -75
16:12:23 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -87, signal strength -87
16:12:27 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -86
16:12:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:12:51 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -85
16:13:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
16:13:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -84
16:13:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
16:13:10 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -78
16:13:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:13:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -84
16:13:25 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
16:13:34 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -83
16:13:40 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
16:13:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -81
16:13:56 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:13:56 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -82
16:18:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:18:47 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -72
16:21:44 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
16:21:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -77
16:22:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
16:22:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -79
16:22:11 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
16:22:11 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -80
16:22:17 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
16:22:17 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -77
16:23:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
16:23:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -78
16:23:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -51
16:23:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -78
16:24:19 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, extensive data loss, signal strength -52
16:24:38 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
16:24:38 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
16:32:40 caps,info 22:41:B9:08:40:F5@MikroTik-DOM1-5GHz rejected, forbidden by access-list
16:32:40 caps,info 22:41:B9:08:40:F5@MikroTik-DOM2-5GHz rejected, forbidden by access-list
16:32:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -75
16:32:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -84, signal strength -84
16:32:59 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:33:01 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:33:10 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
16:33:19 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
16:33:19 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:33:24 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -74
16:33:39 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
16:33:42 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -53
16:34:06 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, extensive data loss, signal strength -55
16:34:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -75
16:34:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -50
16:34:14 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -75
16:34:22 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
16:34:34 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:34:35 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -79
16:34:38 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
16:34:38 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, extensive data loss, signal strength -53
16:34:40 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -80
16:34:46 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -84, signal strength -84
16:34:59 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:35:04 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -79
16:35:19 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
16:35:21 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -78
16:35:24 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
16:35:28 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -78
16:35:49 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
16:35:50 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -79
16:35:53 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -81, signal strength -81
16:35:55 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -79
16:36:07 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -89, signal strength -89
16:36:07 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:36:11 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:36:13 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -58
16:36:13 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:36:13 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -87
16:36:13 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, registered to other interface, signal strength -58
16:36:22 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, extensive data loss, signal strength -87
16:36:34 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:36:40 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:36:40 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -86
16:36:43 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:36:43 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:36:49 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:36:49 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 connected, signal strength -87
16:36:50 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -57
16:36:50 caps,info 02:42:7C:F8:B7:87@MikroTik-SAD-1 disconnected, registered to other interface, signal strength -87
16:36:57 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, extensive data loss, signal strength -58
16:37:45 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
16:37:45 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -39
16:38:10 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:38:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
16:39:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
16:39:00 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:39:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -57
16:39:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -72
16:39:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -57
16:39:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -86, signal strength -86
16:39:08 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
16:39:12 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
16:39:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -54
16:39:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -76
16:39:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, extensive data loss, signal strength -56
16:42:37 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -75
16:43:04 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:43:05 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -69
16:44:11 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:44:12 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
16:44:12 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
16:44:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
16:44:20 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -81
16:44:41 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -89, signal strength -89
16:44:41 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -81
16:44:44 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -92, signal strength -92
16:44:44 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:44:45 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -86
16:44:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -92, signal strength -92
16:44:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
16:45:03 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
16:45:13 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -76
16:45:28 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
16:46:19 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:47:42 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
16:47:42 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -37
16:47:42 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -50
16:48:07 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, extensive data loss, signal strength -50
16:49:06 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:51:06 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:52:10 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:56:49 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
16:57:49 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -64
16:57:50 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -70
17:04:47 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, too weak signal, signal strength -88, signal strength -88
17:04:47 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:04:49 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:04:51 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:04:57 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:04:58 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -53
17:05:06 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:05:09 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:05:10 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 reassociating
17:05:10 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -57
17:05:13 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:05:26 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:05:30 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:05:33 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:05:40 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -88, signal strength -88
17:05:43 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
17:05:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -88, signal strength -88
17:05:48 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:05:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -56
17:05:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 rejected, forbidden by access-list
17:05:50 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, received deauth: unspecified (1), signal strength -54
17:05:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -75
17:05:54 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, registered to other interface, signal strength -54
17:06:02 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:06:20 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:06:39 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:06:56 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:06:57 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -51
17:07:02 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:07:03 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
17:07:03 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -38
17:07:11 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:07:13 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 reassociating
17:07:13 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -54
17:07:25 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:07:37 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, extensive data loss, signal strength -57
17:07:44 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:03 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:08 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:11 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:11 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
17:08:11 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -37
17:08:16 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:22 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:31 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:45 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
17:08:45 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
17:08:45 system,info,account user admin logged in from 89.113.47.239 via winbox
17:08:45 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 rejected, forbidden by access-list
17:08:56 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -83, signal strength -83
17:08:58 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -87
17:09:01 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -91, signal strength -91
17:09:02 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -75
17:09:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, too weak signal, signal strength -82, signal strength -82
17:09:52 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 connected, signal strength -86
17:09:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-SAD-1 disconnected, too weak signal, signal strength -90, signal strength -90
17:09:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -76
17:10:16 system,info wireless access-list rule changed by admin
17:10:21 system,info wireless access-list rule changed by admin
17:10:21 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 disconnected, access-list changed, signal strength -77
17:10:21 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 disconnected, access-list changed, signal strength -54
17:10:21 caps,info FC:F5:C4:82:D9:CE@MikroTik-DOM2 disconnected, access-list changed, signal strength -35
17:10:21 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 disconnected, access-list changed, signal strength -40
17:10:21 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, access-list changed, signal strength -54
17:10:24 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 connected, signal strength -39
17:10:26 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -70
17:10:34 caps,info FC:F5:C4:82:D9:CE@MikroTik-DOM2 connected, signal strength -35
17:17:14 caps,info 8C:CE:4E:CC:78:83@MikroTik-DOM2 connected, signal strength -35
17:19:49 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 connected, signal strength -81
17:26:56 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
17:28:09 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 connected, signal strength -53
17:28:09 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM2 disconnected, registered to other interface, signal strength -85
17:28:13 caps,info 02:42:7C:F8:B7:87@MikroTik-DOM1 disconnected, extensive data loss, signal strength -54
17:29:07 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -39
17:29:52 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
17:29:52 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -40
17:29:59 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
17:29:59 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -55
17:30:55 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
17:30:55 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -40
17:32:44 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 disconnected, extensive data loss, signal strength -55
17:32:46 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 reassociating
17:32:46 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 connected, signal strength -40
17:34:13 caps,info 8C:CE:4E:CC:AB:C1@MikroTik-DOM1 disconnected, received disassoc: sending station leaving (8), signal strength -39
17:38:53 caps,info 8C:CE:4E:CC:78:83@MikroTik-DOM2 disconnected, extensive data loss, signal strength -37
17:38:58 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 disconnected, extensive data loss, signal strength -42
17:39:06 caps,info 8C:CE:4E:CB:8E:F0@MikroTik-DOM2 connected, signal strength -38
17:39:06 caps,info 8C:CE:4E:CC:78:83@MikroTik-DOM2 connected, signal strength -37
17:58:27 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:15:21 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:15:21 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
18:17:25 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:17:25 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:21:06 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:21:06 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
18:21:29 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:21:29 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:22:56 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:22:56 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:25:25 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:25:25 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:30:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:30:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
18:37:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:37:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:39:21 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:39:21 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:40:26 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:40:26 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:43:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:43:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:44:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -59
18:44:50 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -80
18:44:51 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 reassociating
18:44:51 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -59
18:44:55 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, extensive data loss, signal strength -60
18:48:22 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:48:22 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:49:10 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 disconnected, received disassoc: sending station leaving (8), signal strength -54
18:50:09 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:50:46 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -80
18:50:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 connected, signal strength -55
18:50:48 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, registered to other interface, signal strength -80
18:50:51 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM1 disconnected, extensive data loss, signal strength -55
18:51:10 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:51:10 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -52
18:53:01 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:53:01 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
18:54:12 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:54:12 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -52
18:59:09 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
18:59:09 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -55
19:03:28 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
19:03:28 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
19:07:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
19:07:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
19:07:41 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
19:07:41 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
19:08:35 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -82
19:09:30 system,info,account user admin logged out from 89.113.47.239 via winbox
19:10:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
19:10:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
19:11:41 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 disconnected, received disassoc: sending station leaving (8), signal strength -82
19:12:07 caps,info 2A:D5:A7:44:C6:02@MikroTik-DOM2 connected, signal strength -80
19:12:16 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
19:12:16 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
19:13:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
19:13:08 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -54
19:16:11 system,info,account user admin logged in from 37.112.250.159 via winbox
19:16:11 system,info,account user admin logged out from 37.112.250.159 via winbox
19:16:22 system,info,account user admin logged in from 37.112.250.159 via winbox
19:18:51 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 reassociating
19:18:51 caps,info 8C:CE:4E:CB:8E:CD@MikroTik-DOM1 connected, signal strength -53
19:19:03 system,info,account user admin logged in from 37.112.250.159 via telnet
