is 711 board is good for 5 kilometer
hi there
i made a p2p with 7115hn and is configured in 5ghz (bridge mode )
and freq is 5280
band is 5gh only N
cust complain that they can’t gaining the 4mbps link.
we are providing 4mbps link on it.
signal strangth is -69 both side. and tx/rx ccq is 89/92remote site
the remote site is approx 5km away from my broadcasting center.
so what should i do ???
customer is using public ip
plz do the needful
With appropriate antenna 711 board can do great job for loooonger distance.
Check /interface wireless registration-table for data-rate customer get, and make sure all wireless parameters are used as default.
We are getting 8-10 mbps UDP with bandwidth test on rb711 with grids on both sides and signal -69/70 ccq 70/75%
thanks for replying
but i am using inbuilt anteena 22dbi
and signal and ccq is good now we are encreasing the bandwidth on it (6mbps), is there any touble .
can i mount an external anteena on 711 5hn board.
take the 711 out of ur 22dbi box and get a seperate enclosure where u can connect it to a grid. u’d also need a MMCX to Ntype female connector, AND A LMR400 PIGTAIL TO CONNECT TO THE FEEDER OF UR GRID/DISH
can you send the GPS coordinates of your locations? i will check them in Radio Mobile and submit the screenshots.
