Is a backup default location change possible?
Hi guys,
Currently the .backup file is stored in the RAM of my MikroTik-hEX (RB750Gr3) and gets lost after reboot.
Can I change the default location for backups that they will be automatically saved either in flash section or on the attached SD card?
Thanks!
You. Can’t change the default location and you have to move manually the backup to a mounted SDcard or to you PC.
Don’t forget mark the question solved by clicking/tapping th white cross in the green box when this answer is sufficient.
Thanks very much, msatter!
