My aim is to route traffic via certain wan connections depending on the type of connection.
In other words, route http and https traffic via wan1 and all other via wan2.
This works but I don’t understand why I need a default route. Please bear with me as I share my set-up.
Two WAN connections via ADSL with dynamic addresses. Clients are on the LAN and are NATted.
add action=masquerade chain=srcnat comment=\
"masquerade allowed local addresses via wan1" disabled=no
out-interface=wan1 src-address-list=local-allowed
"masquerade allowed local addresses via wan2" disabled=no \
out-interface=wan2 src-address-list=local-allowed
Then my mangle rules;
Firstly I mark my connections
/ip firewall mangle
add action=jump chain=prerouting comment="" connection-state=new disabled=no \
jump-target=tcp-services protocol=tcp
jump-target=udp-services protocol=udp
jump-target=other-services
add action=mark-connection chain=tcp-services comment=http disabled=no \
dst-port=80 new-connection-mark=http passthrough=no protocol=tcp \
src-port=1024-65535
add action=mark-connection chain=tcp-services comment=https disabled=no \
dst-port=443 new-connection-mark=https passthrough=no protocol=tcp \
src-port=1024-65535
dst-port=8080 new-connection-mark=http passthrough=no protocol=tcp \
src-port=1024-65535
add action=mark-connection chain=tcp-services comment="other tcp" disabled=no \
new-connection-mark=other-tcp passthrough=no protocol=tcp
add action=mark-connection chain=udp-services comment="other udp" \
connection-state=new disabled=no new-connection-mark=other-udp \
passthrough=no protocol=udp
add action=mark-connection chain=other-services comment=other disabled=no \
new-connection-mark=other passthrough=no
Then I mark the packets;
add action=mark-packet chain=prerouting comment="" connection-mark=http \
disabled=no new-packet-mark=http passthrough=no
add action=mark-packet chain=prerouting comment="" connection-mark=https \
disabled=no new-packet-mark=https passthrough=no
add action=mark-packet chain=prerouting comment="" connection-mark=other \
disabled=no new-packet-mark=other passthrough=no
add action=mark-packet chain=prerouting comment="" connection-mark=other-tcp \
disabled=no new-packet-mark=other-tcp passthrough=no
add action=mark-packet chain=prerouting comment="" connection-mark=other-udp \
disabled=no new-packet-mark=other-udp passthrough=no
Then I mark the routing;
add action=mark-routing chain=prerouting comment=http disabled=no \
new-routing-mark=http packet-mark=http passthrough=no
add action=mark-routing chain=prerouting comment=https disabled=no \
new-routing-mark=https packet-mark=https passthrough=no
add action=mark-routing chain=prerouting comment=other-tcp disabled=no \
new-routing-mark=other-tcp packet-mark=other-tcp passthrough=no
add action=mark-routing chain=prerouting comment=other-udp disabled=no \
new-routing-mark=other-udp packet-mark=other-udp passthrough=no
add action=mark-routing chain=prerouting comment=other disabled=no \
new-routing-mark=other packet-mark=other passthrough=no
Then I add the routes;
add comment="default route" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan1
add comment=http disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan2 \
routing-mark=http
add comment=https disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan2 \
routing-mark=https
add comment=other disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan1 \
routing-mark=other
add comment=other-tcp disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
wan1 routing-mark=other-tcp
add comment=other-udp disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
wan1 routing-mark=other-udp
Now here’s my question;
Why do I need this routing rule?
I would have thought that by identifying ‘everything else’ via connection-mark, then packet-mark, then route-mark, the traffic would simply obey the routing rules and go via wan1 whereas http and https goes via wan2.
This all ‘sort-of’ works but only if I enable the default rule. I just don’t see why if I’ve marked all other traffic and then routed it, do I need this default rule.
For some other reason, I seem to have load balanced everything rather than policy routing based on marked connections.
My guess is that I’m not catching all the packets somehow.
Thanks for staying with me.
