Is a tunnel's tunneling
I need to ensure that an eoip tunnel is up and running. But I failed to find a way to detemine his state. How could that be done?
You can run netwatch to monitor remote tunnel address.
It does work. Very easy to put in place. Not a clean solution however…
Should I consider another type of tunnel? Looks like eoip lacks some features.
Dany
