Is any one running 2x SR5's and 2x CM9s in an RB500?
Is any one running 2x SR5’s and 2x CM9s in an RB500?
im told it wont work as the SRs draw to much power?
You would be correct. You’re pretty much maxed out with 2 sr’s. The issues from my understanding is the power regulators on the the MB is the limiting factor the 3.3v supply in particular.
Erik
Joke: Think about volt mod :slight_smile:.
P.S. There is drop of truth in every joke :wink:.
It will not work!! We have tried it on our ap at local watertower and it had constant problems with signal and clients disconecting constantly. We changed to prism and it works wery fine. We tried to use 3 x sector antenas on 2 RB 500 and where there is one card forks great an other one const. problems. So i think it is not a good idea to do that.
Hi there Jrslick22, your new zealand? flick me your number and ill give ya a call geoff at airstream dot net dot nz.
Geoff
