http://www.zte.com.au/telstra/Product_Downloads/MF633_downloads.htm
I have it plugged in to a 433UAH and it is detected as per:
[admin@SkunkMikrotik] /system resource usb> print detail
0 device="2:1" name="RB400 EHCI" serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0002" speed="480 Mbps" ports=2 usb-version="2.00"
1 device="2:2" vendor="ZTE,Incorporated" name="ZTE Configuration" serial-number="1234567890ABCDEF" vendor-id="0x19d2" device-id="0x0031" speed="480 Mbps" ports=0 usb-version="2.00"
2 device="1:1" name="RB400 OHCI" serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0001" speed="12 Mbps" ports=2 usb-version="1.10"
PIN on the device is disabled.
I can’t get it connected though no matter what setting I try in the ppp interface. I do see it as available as port usb2 in the ppp interface when creating it.
Anyone know what data/information channel I should be using?
This device is not on the confirmed hardware list, should I perhaps be sending in a supout?
I’m using no modem init string, *99# as the phone number and telstra.datapack as the APN
System detail:
[admin@SkunkMikrotik] /system routerboard> print
routerboard: yes
model: “433UAH”
serial-number: “1E44019FE5FB”
current-firmware: “2.29”
upgrade-firmware: “2.29”
MikroTik RouterOS 5.0rc10
