In our “wAP ac” ROS 6.45.7 “/interface wireless info country-info portugal” reports:
ranges: 2402-2482/b,g,gn20,gn40(20dBm)
2417-2457/g-turbo(20dBm)
5170-5250/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(23dBm)/passive,indoor
5170-5330/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(20dBm)/dfs,passive,indoor
5250-5330/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(20dBm)/dfs,passive,indoor
5490-5710/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(27dBm)/dfs,passive
5190-5310/a-turbo(20dBm)/dfs
5180-5300/a-turbo(20dBm)/dfs
5520-5680/a-turbo(27dBm)/dfs,passive
5510-5670/a-turbo(27dBm)/dfs,passive
902-927/b,g,g-turbo,gn20,gn40(30dBm)
But with the interface is correctly configured for the country regulatory domain the total power reported is only 18dBm with the card producing 15dBm and the default (minimum) antenna-gain is 2dB (information from WEBFIG)
/interface wireless monitor [find default-name=wlan1] once
status: running-ap
channel: 2437/20/gn(18dBm)
wireless-protocol: 802.11
noise-floor: -95dBm
overall-tx-ccq: 81%
registered-clients: 1
authenticated-clients: 1
wmm-enabled: yes
current-tx-powers: 1Mbps:15(15/18),2Mbps:15(15/18),5.5Mbps:15(15/18),11Mbps:15(15/18),6Mbps:15(15/18),9Mbps:15(15/18),12Mbps:15(15/18),18Mbps:15(15/18),24Mbps:15(15/18),36Mbps:15(15/18),48Mbps:15(15/18),54Mbps:15(15/18),HT20-0:15(15/18),HT20-1:15(15/18),HT20-2:15(15/18),HT20-3:15(15/18),HT20-4:15(15/18),HT20-5:15(15/18),HT20-6:15(15/18),HT20-7:15(15/18)
notify-external-fdb: yes
If the maximum EIRP is 20dBm and the antennas in the device are reported to have 2dB of gain in this device, the card should produce 18dBm itself so the additional antenna gain will result in a signal within the regulatory limits. Am I missing something?
As a test, if the antenna gain is defined to be as an example 10dB, the reported “Total Tx Power” is reduced to 10dBm so, it seems the effect of the antenna gain is being subtracted to the “Total Tx Power” instead to the “Tx Power” (card).
I also don’t understand the origin of the 3dB difference reported between the “Tx Power” and the “Total Tx Power” it should be the antenna gain no? …
This results in worst conditions of connectivity to Mikrotik devices as compared to other manufacturers in similar conditions.
Our users are pointing to the Mikrotik devices telling “the signal were better with the old network” …
regards.
