gechev
September 2, 2016, 4:39pm
1
> ip firewall filter print where chain =forward
0 D ;;; special dummy rule to show fasttrack counters
chain=forward
1 chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
2 chain=forward action=accept connection-state=established,related log=no log-prefix=""
> ip firewall filter print stats where chain =forward
# CHAIN ACTION BYTES PACKETS
forward 0 0
1 forward fasttrack-connection 132 736 494 928 167 940 926
2 forward accept 132 736 494 928 167 940 926
Any idea about zero counters?
gechev
September 7, 2016, 9:44pm
2
Another info:
> ip settings print
ip-forward: yes
send-redirects: yes
accept-source-route: no
accept-redirects: no
secure-redirects: yes
rp-filter: no
tcp-syncookies: no
max-neighbor-entries: 8192
arp-timeout: 30s
icmp-rate-limit: 10
icmp-rate-mask: 0x1818
route-cache: yes
allow-fast-path: yes
ipv4-fast-path-active: no
ipv4-fast-path-packets: 0
ipv4-fast-path-bytes: 0
ipv4-fasttrack-active: yes
ipv4-fasttrack-packets: 0
ipv4-fasttrack-bytes: 0
Is it possible to be something related to the hardware?
> system routerboard print
routerboard: yes
model: 750G
serial-number: 228E01AC2263
firmware-type: ar7100
factory-firmware: 2.23
current-firmware: 3.24
upgrade-firmware: 3.24
Manual says for fast-track:
RB7xx series all ports
Does 750G belong to mentioned 7xx series? It is 750G, not 750GL:
> system resource print
uptime: 5h15m38s
version: 6.36.3 (stable)
build-time: Sep/05/2016 08:09:03
free-memory: 8.1MiB
total-memory: 32.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 680MHz
cpu-load: 2%
free-hdd-space: 49.9MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 501
write-sect-total: 528504
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB750G
platform: MikroTik
P.S. Just before submitting the post I found another router 750G in my network and it has the same counters.
razavim
September 7, 2016, 10:27pm
3
I believe fast track is not functional on 7th series
check MUM 2016 USA you may find a good presentation about fast track on youtube.
Sent from my SM-N910C using Tapatalk
jarda
September 8, 2016, 9:13am
4
Fasttrack works fine for me on RB751U-2HND, for example.
gechev
September 8, 2016, 11:49am
5
Yes, it is not related to the whole 7xx series, I have RB750 working fine too.
kabal
September 9, 2016, 6:47pm
6
On my RB750G fasttrack does not work, maybe old switch chip
jarda
September 9, 2016, 7:53pm
7
fasttrack has no reation to switch
kabal
September 10, 2016, 8:56am
8
Reset config and update to last ROS version.
[admin@MikroTik] > ip settings print
ip-forward: yes
send-redirects: yes
rp-filter: no
tcp-syncookies: no
arp-timeout: 30s
icmp-rate-limit: 10
route-cache: yes
[admin@MikroTik] > system routerboard print
routerboard: yes
model: 750G
serial-number: 268D017C001F
factory-firmware: 2.27
Anyone know why my counter for fasttrack says 0 on both client and server Grooves?
I was getting 90 Mbits but these days I get barely 30Mbits in bandwidth test… I dont know what is going on, thinking that maybe one Groove has a hardware failure
On my CCR, Fasttrack does not become active until I enable Route Cache (RouterOS v6.38.5) - maybe it should be mentioned in the Manual ?
