Is forward chain firewall rules necessary?
Here is my entire firewall config for my home router:
Code: Select all
/ip firewall address-list
add address=w.x.y.z list=Whitelist
add address=a.b.c.0/23 comment=“Work” list=Whitelist
add address=d.e.f.0/23 comment=“Customer” list=Whitelist
add chain=input comment=“Permit existing connections” connection-state=established,related
add chain=input comment=“Allow all ICMP” protocol=icmp
add chain=input comment=“Allow whitelisted sources” src-address-list=Whitelist
add action=drop chain=input comment=“WAN - default deny” in-interface=ether6
add action=src-nat chain=srcnat comment=“Use correct src-ip when talking to DOCSIS modem.”
dst-address=192.168.100.0/24 out-interface=ether6 to-addresses=192.168.100.2
add action=masquerade chain=srcnat out-interface=ether6 to-addresses=0.0.0.0
Hi Mikrotik users, was wondering if it is necessary to include forward chain firewall rules for a typical home router? The above mentioned configuration is from Zerobyte in one of his post in this forum. It did not include forward chain rules?
Always depends if you want to protect the router only or the inner network (networks) too.
Hi jarda, isn’t NAT suppose to protect the internal private ip network since only when internal ip transmits a data packet will the return data packet be allowed? Or am I missing something?
If the packet arriving to wan interface will have dst address of existing inner network segment, the router will route that packet.
Nat is not supposed to protect anything.
from manual:
connection-nat-state (srcnat | dstnat; Default: ) > Can match connections that are srcnatted, dstnatted or both. Note that connection-state=related connections connection-nat-state is determined by direction of the first packet. and if connection tracking needs to use dst-nat to deliver this connection to same hosts as main connection it will be in connection-nat-state=dstnat even if there are no dst-nat rules at all.
So my firewalls usually starts with:
add action=fasttrack-connection chain=forward connection-state=established,related
add chain=forward connection-state=established,related
add action=drop chain=forward connection-nat-state=!dstnat in-interface=<Internet>
