Is IPv6 port redirection possible?
on IPv4 I redirect port 444 to 443 in order make it harder to find my RouterOS login.
Can something equal be done with IPv6? E.g. I want to redirect all traffic from the WAN arriving on port 444 to 443 on my router?
Thanks,
dksoft
Obscuring is not that effective and better do limit access to that address and port by sourceIP filtering or Port Knocking before granting access.
Tip about port knocking, that I learned here, is to use the established state for keeping the connection instead of a set time in addresslist.
And no, Mikrotik does not support NAT and PAT on IPv6.
Example and use should you own ports and sequence:
add action=accept chain=input comment="Stateful (established only)" connection-state=established
add action=accept chain=input connection-state=new port=443 protocol=tcp src-address-list=WinboxAccess
add action=add-src-to-address-list address-list=port_knock address-list-timeout=2s chain=input comment=Knocking dst-port=1234 protocol=tcp
add action=add-src-to-address-list address-list=port_knock_1 address-list-timeout=2s chain=input dst-port=2341 protocol=tcp src-address-list=port_knock
add action=add-src-to-address-list address-list=port_knock_2 address-list-timeout=2s chain=input dst-port=3412 protocol=tcp src-address-list=port_knock_1
add action=add-src-to-address-list address-list=WinboxAccess address-list-timeout=1m chain=input dst-port=3412 log=yes protocol=tcp src-address-list=port_knock_2
You can use also UDP instead of TCP ports or even mix UDP and TCP. After successful knocking you have one minute (1m) to login from external into Winbox.
