IS-IS menu in Winbox
Why doesn't the IS-IS menu appear graphically in Winbox? It's been several versions since it was added or updated.
I'm sure it's on the list for Winbox 4. I'd like to see it as well :nerd_face:
Well into 2026 by now and still waiting for the IS-IS in Winbox! :sweat_smile:
@Mikrotik: Please deliver us from our suffering :innocent:
7.22 is still in development, hopefully this can be the lucky number?? :wink:
i would also appreciate the isis routing option in winbox.
should be doable in 2026 :wink:
I thought the Miracle has happened, but I can’t seem to find it yet!
From the 7.22rc3 changelog:
* winbox - added route ISIS tab;
https://mikrotik.com/download/changelogs?channelFilter=testing
Where exactly should I look? I see no ISIS submenu under routing, tried with latest 4.0.1 and 3.43.
Thanks!
it’s not actually adding routing menu
but adds IS-IS tab in ip/route
So it’s just 2 columns for now?
That’s kind of an anti-climax! Really hoping to see full ISIS management in Winbox soon.
yea, all of us do
