Is it good using Load Balancing PCC or NTH or Static Route ?
First of all thank you for your attention,
i had problem, on my office there is 2 gateway :
  1. an extranet /vpn /intranet (actually i don’t know, is it vpn or extranet or intranet).
    function : for this network is user can exchange private data that only can be accessed on this network.
  2. an internet up to 1000Mpbs.
and the configuration that already used is :
one dhcp server :
192.168.222.0/22
static IP addresses from manual configuration:
172.168.1.1 - 172.168.1.100
and i have 800 user that connected on my wireless and 200 user that connected on wire.
i would like to route user network to go as they need, i mean user can use two gateway at the same time. without to change ip address. and go to gateway 2 for public internet and go to gateway 1 for private internet.
and my question is
  1. what i have to use ? pcc or nth or static route ?
    if i’m using static route, some article said “it’ll be easy to get overload”
    and if i’m using nth it’s not compatible on my web application.
    if i’m using PCC, some article said " it’ll be easy to get overload"
    what i’m confused, is it true or not ? and what causes overload and disconnect? is it depends on my hardware ?
  2. does router board mikrotik have special configuration to transfer 800mbps conection to the cisco access point ? is it depends on the user who receive the connection ?
i’m sorry if i’m wrong, i’m still newbie. and sorry my writing english bad
