Hi!
Planing to set up a ptp link and i’am wondering if the LOS is acceptable?
We need a stable link and minimum of 15/15 mbit.
The antenna on the picture will be about 2m higher.
The other end where i’am standing will be as high as possible. Mayby about 4-5m.
Distance is about 780m.
click the picture to see actual size.
No problem, but you’ll need to control the growth of the tree.
jcem
3
Precis vad jag tänkte säga. Lövträd med blad när det regnar suger signal
Men jag tror inte du kommer ha några problem här med 15Mb
Lycka Till!
Jörgen
May by the tree will die in the future
What about the hardware? Should I use SXT? Or should I use something else like a Groove whit an antenna that has very low beam?
Remember that this link must be stable.
jcem
5
SXT should be fine - then you can run 2 chains
Jörgen
