I am using RouterOS. I want to give bandwidth to my users by the following system:
We have 10 Group of users and every group will get same amount of bandwidth. This group will be decided by me. Suppose, a file which contains list of IP addresses or I can use AddressList. But I need also every users graphs. So I made each simple queue for each user.
Sorry I cant make you understand.
I have more than 1600 user. I want to change up/down limit by script so that I need to change only 10 times (coz. I have 10 groups).
It is very dificult to change 1600 users up/down limit. I just want to assign up/down limit for a group.
Example: Group A hold IP address 192.168.1.10, 192.168.1.15-30, 192.168.1.205-209.
Group B hold IP address 192.168.1.3, 192.168.1.9-12, 192.168.1.105-109.
etc.
if you must create simple queue for each user, then simply set queue type to PCQ w/o classifier. create different PCQ types for different groups - then you will simply change PCQ rate to change up/down limit
anyway, 1600 simple queues are crazy idea. you better create queues in queue tree with PCQ. you may graph each users’ bandwidth using NetFlow information
