I have an issue with my dynamic dns update client. I have multiple external connections each with a unique dynamic dns name.
The problem is that one of the external accounts only has reliable access to IP’s inside the border of my country. But I require this connection to update with a dynamic dns server outside of the country.
Is it possible to use one of the connections which have full external access, but to change its source address to the IP of the connection which has limited access? A sort of masquerade if you like?
The packets that I would like to manipulate always originate from 192.168.1.6 with destination 207.67.0.0/16, it should display the ip of pppoe-local but by using pppoe-international…
