is it possible to create a peer template that is used everytime I connect via the L2TP transport tunnel?
Via the “auto IPSec” fuction the peer generated is quite useless:
The upper peer is what I want to have, the lower one is generated everytime the l2tp tunnel is brought up.
I cannot enter them statically as the IP Address will be changing on one side outside the lab.
0 address=10.0.0.11/32 local-address=:: passive=no port=500
auth-method=pre-shared-key secret=“1234” generate-policy=no
policy-template-group=default exchange-mode=main-l2tp
send-initial-contact=yes nat-traversal=yes hash-algorithm=sha512
enc-algorithm=“” dh-group=modp4096 lifetime=1d dpd-interval=2m
dpd-maximum-failures=5
1 D address=10.0.0.11/32 local-address=:: passive=no port=500
auth-method=pre-shared-key secret=“1234” generate-policy=port-strict
send-initial-contact=yes nat-traversal=yes hash-algorithm=sha1
enc-algorithm=aes-256,aes-192,aes-128,3des dh-group=modp1024 lifetime=1d
dpd-interval=2m dpd-maximum-failures=5
The autogenerated one has to many weak parameters that I do not want to use.
Is there any possibility to change the default peer parameters?
Best Regards!
