I’m trying to create pure L2 OpenVPN tunnel in ethernet mode but ROS keeps assiging default dynamic IP to ovpn interfaces on both sides. Can I prevent that? I’d like to just lay VLANs on tunnel interface
I’m not sure if it’s just RouterOS. I remember (well, vaguely, it was very long time ago, so I can be mistaken) that I had problem with getting rid of addresses even with original OpenVPN. You can test if it’s possible with that and only RouterOS is doing something unexpected, or if perhaps addresses are tied to protocol.
It turns out it doesn’t want to establish tunnel without IP. I guess I’ll just need to use some dummy /30 network
