Is it possible to make a clean install of RouterOS without Netinstall?
Hi everyone!
I’m currently trying to create an automated platform to manage new installations of RouterOS and set custom configurations on each device (The script generation is done with external logic). I would like to know if it’s possible to use different tools (preferably via CLI) to make new installations of RouterOS and customize default configuration scripts. After using Wireshark, I noticed that Netinstall is using BootP, DHCP and TFTP, but I don’t know which steps to follow in order to replicate the same process.
Does someone here know how to make a solution like this? If it’s possible, I would appreciate some help.
Thanks in advance!
Install them where exactly? On what platform?
I was talking about, for example, create a solution on Linux in which you could make Netinstall process via CLI or Bash Script using generic TFTP/BOOTP servers.
I know, but you did not answer my question. There might be different solutions for different architectures.
been looking for solution to this but I don’t think it’s possible
Oh sorry, I misunderstood your question. Now I’m currently working with the model RB2011UiAS-2HnD-IN (MIPSBE)
EDIT: I was able to configure a BOOTP server & TFTP server and replicate netinstall operations in terms of assigning IPs and transfering the vmlinux image to the router. However, I still don’t know what does the MT Netinstall Server does. After using Wireshark, I noticed that it uses UDP port 5000 to transfer the NPK file, the default script file and other configuration with a strange structure of messages (I tried decoding the pcap packages as TFTP with no success so I assume that in this step it’s not used). Here I copy some examples in case you know what kind of protocol is:
..',J...B...........OFFR
..',J...B.............',J...B.............',J...B.............',J...B.............',J...B.....).....FILE
routeros-mipsbe-6.45.7.npk
12060310
12060310
12060310
12060310
..',J...B..................... ...routeros-mipsbe..f-.sd.]..............stable......mips..B...RouterOS for mipsbe RouterBOARDs, includes all supported features
........".....ipv6..............................$...system...........f-.sd.]..................mips..,...Main package with basic services and drivers.
-----------------------------------AFTER TRANSFERING FILE NPK FILE--------------------
5.......................................>...........................................................G.........................d.].f-.sd.].... ...../var/pdb/system/crcboot/kernel 1963032758
boot
. 2
.'|.	.D...7K....:...vg..D.4.
-----------------------------------AFTER THIS, IT COPIES DEFAULT SCRIPT CONTENT--------------------
......I..',J...B.......w v ..',J...B.......w v ..',J...B.......x w FILE
autorun.scr
6329
autorun.scr
6329
From your message about getting tftp running, are you saying that with bootp and tftp set up I could replicate the ‘most important’ bits of netinstall.exe from a linux machine? I don’t mind forcing a factory reset via reset button if that steps needed. You write about transferring the NPK file and the VMlinux file… I thought there was only the NPK, so I’m confused.
We’re windows-free here, I’ve just had to resort to borrowing a windows laptop to upgrade my hAP-lite
David
Ps, for what it’s worth, netinstall via wine on my linux box(es) just sits there saying,
bootp req received
bootp recv bytes: 300
client: 4C:5E:0C:F0:35:49
bootp req received
bootp req received
Other runs throw in ‘reply not sent’ or something similar, but the result is the same, it’s non-functional.
