Hallo,
I have a server behind a router that is on a different network B and is often in sleep mode. A ping or a WoL in this network would wake him up. However, this does not happen from network A.
My idea now is to detect a ping from network A to this server and then send a command that wakes up the server:
You might think that WoL is a unicast protocol given the MAC address, but it’s not; it’s based on a subnet-directed broadcast packet. It has to work that way because it can’t rely on ARP mappings, the FDB, etc. That much is true inside network B, but even more so in network A, where it couldn’t see network B’s ARP table or its FDB even if it wanted to. We speak of “broadcast domains” for this very sort of reason.
I’m not aware of any “run a script on ping packet” functionality in RouterOS, and if there were such a thing, I would consider it a massive layering violation, tying one of the OS’s lowest layers (packet filtering) to one of its highest layers (scripting). Yuck.
But one possibility is to have a firewall filter rule that matches the desired ping, and then does action=log. A schedule script could then search logs for that message, and run the desired script.
Thank you very much for your answers. My background is that I operate a 24/7 media server in the home network, which should be as energy-saving as possible but also “convenient”. The clients in the network should be able to access shares and media without having to explicitly wake up the server every time. In addition, it is supposed to go back into energy-saving mode after a relatively short time when idle.
I have therefore disabled “Only WoL can wake up device” in the network settings. This, of course, then leads to the fact that any network activity prevents sleeping. That’s why I came up with the idea with the router, because these activities are not routed for the time being. On the other hand, a targeted request to the server should be able to wake it up from hibernation. But from the looks of it, that doesn’t seem possible. What a pity.
Okay, new solution: use Home Assistant to react to a TV “power-on” event and send the WoL packet/SSH call from there.
How exactly you go about that depends on the type(s) of displays involved, what type of set-back boxes you’ve got running, whether there’s an active CEC link you can tap into, etc.
Worst case, buy one of those hackable $9 power plugs like the Sonoff S31, reflash it with ESPHome, and detect power-on by the jump in current draw. Wake the server, and by the time the user gets around to drilling down into Plex or whatever, the server is awake and ready to respond.
@tangent
Yes, this should be possible for the scenario described. However, the server is mainly used by clients in the Windows network.
But it’s a nice idea for my raspberry with kodi
So wrap the call to the Windows player GUI in a script that sends the SSH “wake” call to the router first.
If you’re worried about handing out SSH logins to allow this, you can put the call into a *.rsc file and set the dont-require-permissions flag on it, so read-only users can call it.
