Hi Guys,
We have a lot of customers that connect via PPPoE.
We have PPP Profiles setup and use RADIUS to authenticate the users and assign them to an address list which is attached to a profile.
We do other stuff with queue trees etc. after this. However, I don’t think any of the additional things we do are relevant to my question.
My question is as follows: Is it possible to specify a custom DNS setting per profile?
Currently, when I add a custom DNS to a profile it is ignored. The connected user simply gets what ever is configured under IP>DNS.
Hi
It is possible to have different DNS setting per profile you add to your router,but should notice while you enable IP/DNS and redirect the udp port 53 for your client it doesn’t work properly,first disable ip/dns setting in your router,delete unnecessary firewall rules and use external dns server for your users,after that you can have different dns setting for profile part in router.
I’m sorry. I don’t quite understand what your instructing me to do.
Could you please write it in bullet pointed steps.
Thanks.
Sent from my iPhone using Tapatalk
Can you confirm what you mean by redirect port 53?
Also,
When I disable remote DNS request and specify a DNS server manually under the ppp Profile. When a user connects, they still don’t get a DNS address.
Please can anyone enlighten me as to what I am doing wrong?
Thanks.
