is it possible to update winbox in dude ?
Hello i have Dude 3.5
And i thought to update winbox app inside dude.
2.2.18 is latest, and dude 3.5 which is installed hundred years ago as central server should have older version.
can’t update dude to newest 4.0 beta
Is it possible? Or it is hardcoded in dude exe ?
Winbox operation files are located in the router, that’s what you see when connecting and it says “downloading plugins”. there is no use in updating the loader.
thanks for definition
Hi All,
why, when i use the winbox tool in the dude, I don’t see the safe mode and undo button, the hide password flag ?
How can I solve the problem ?
Thank you.
Dude has an integrated Winbox, which is older than what RouterOS ships with.
You can configure your new winbox as a new tool in the Dude. http://wiki.mikrotik.com/wiki/Manual:The_Dude/Tools
OK,
thank you, but in this case the winbox start but ask me the address the user name and password; how can I send him the variables listed above ?
from the manual http://wiki.mikrotik.com/wiki/Winbox
winbox.exe [<connect-to> [<login> [<password>]]]
for example
winbox.exe 10.5.101.1 admin ""
OK,
solved, thank you!
