Hello, I am using a CCR2116-12G-4S+ w/ hardware offload via fasttrack enabled. I’d like to set up QoS (fq_codel or cake) for upload and download traffic on the interface. Is this possible without turning l3hw offload off? Thank you
No.
It will disable hardware offload on the WAN but local traffic should still have it enabled.
If you have symmetrical upload/download you can use 1 queue type, otherwise you’ll need one for upload and one for download. You’ll need to configure the bandwidth limits here. Change cake-bandwidth to about 90% of your max bandwidth. You’ll also want to tweak it depending on if you’re on Docsis, DSL, LTE, etc.
/queue type
add cake-bandwidth=250.0Mbps kind=cake name=cake-default
or
add cake-bandwidth=250.0Mbps kind=cake name=cake-download
add cake-bandwidth=25.0Mbps kind=cake name=cake-upload
Add the queues to the queue tree. Use the WAN’s interface for the upload and the bridge for the download. I’m not sure if these bucket sizes are optimal.
/queue tree
add bucket-size=0.01 name=cake-upload packet-mark=no-mark parent=ether1 queue=cake-default
add bucket-size=0.01 name=cake-download packet-mark=no-mark parent=bridge1 queue=cake-default
