I an admirator of mikrotik… I use all kind of configuration!
I have one problem that I solved it and want to expose it to everybody!
I use the following configuration: 1P4@2400Mhz, MB gigabyte, 256Ram DDR, 3 minipci R52, one CF SANDISK witk MT 2.9.51! They worked perfectly, but after a while the ping was increasing drastically and checked everthing and I also re-formatted the CF and everthing went to normal! Is it possible? May a cf cand distroy the entire network? How can I transfer the license from it to another?
I hope that thise solution would help others with the same problem!
Best regards
Razvan
