Is Mikrotik discontinued the mANTBox19s product?
because it is not shown on the Mikrotik website.
Still, Miktik has the best alternate option?
or need to go netmatel with Ubiquiti sector antenna??
[/url]
Unfortunately, yes: https://mikrotik.com/product/RB921GS-5HPacD-19S
Have you looked at your local vendors because there is a slim chance they might still have it in stock (based on mine).
Any reason with this or coming with new thing?
Most probably to push out newer products like this equivalent: https://mikrotik.com/product/RB921GS-5HPacD-15S
Yes, there are new AC and AX standard devices.
But antennas have always been Mikrotik’s weak link. So a separate antenna will always be the best option. I would recommend the NetBox 5 ax
