Is Mikrotik Hex S (2025) E60iUGS compatible with HUAWEI MA5671A?
Is Mikrotik Hex S (2025) E60iUGS compatible with HUAWEI MA5671A ?
When i plug MA5671A router doesn't start - only power led working, no port activity. If i unplug SFP - router working ok.
Device: E60iUGS
RouterOS versions: 7.19.4
SFP: HUAWEI MA5671A
Then I would think it is not compatible.
No ?
I can confirm that my Hex S is able to see this SFP module without any issues.
       routerboard: yes
        board-name: hEX S
             model: E60iUGS
     firmware-type: en7562
  factory-firmware: 7.18.2
  current-firmware: 7.20.2
  upgrade-firmware: 7.20.2
and SFP module is detected correctly:
/interface/ethernet/monitor sfp1
                    status: link-ok
          auto-negotiation: done
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
                 supported: 10M-baseT-half
                            10M-baseT-full
                            100M-baseT-half
                            100M-baseT-full
                            1G-baseT-half
                            1G-baseT-full
                            1G-baseX
                            2.5G-baseT
                            2.5G-baseX
             sfp-supported: 1G-baseX
               advertising: 1G-baseX
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: yes
              sfp-tx-fault: no
                  sfp-type: SFP/SFP+/SFP28/SFP56
              sfp-encoding: nrz
        sfp-link-length-sm: 20km
           sfp-vendor-name: HUAWEI
    sfp-vendor-part-number: MA5671A
                    status: link-ok
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
                            10M-baseT-full
                            100M-baseT-half
                            100M-baseT-full
                            1G-baseT-half
                            1G-baseT-full
                            1G-baseX
                            2.5G-baseT
                            2.5G-baseX
               sfp-rx-loss: yes
              sfp-tx-fault: no
        sfp-connector-type: SC
              sfp-encoding: nrz
       sfp-vendor-revision: 0000
    sfp-manufacturing-date: 18-02-09
            sfp-wavelength: 1310nm
           sfp-temperature: 59C
        sfp-supply-voltage: 3.352V
       sfp-tx-bias-current: 4mA
              sfp-tx-power: -40dBm
              sfp-rx-power: -40dBm
