Hi
I am planing to set up small around 10-15 access points to provide hotspot internet.
My question is:
- Does MT hardware can assabled and configure for this kind of configuration?
- What hardware would you recommand me i mean what RB, what miniPCI, card antennas etc.
- Did any of you tried this before? what did you use for hardware?
- I want this Access Point have minimum 3 antennas, send/receive 1 each and 3rd for hotspot clients.
Thank you.
Hi
1-yes,of course!
2-it depends on your environment and the mony you want to pay,you can use RB751 which is a good complete router with a built in wireless card,but if you want to connect 3 antennas you can use rb433(different models),rb435(different models) and 493(different models),you can have 3 wireless cards on all of them.R52Hn is a good wireless card that i used,and you need a pigtail and a box
3-yes,I used hotspot in a wireless mesh network and rb751 and it is so good.
4-hotspot does not need a separate wireless card and you can run hotsopt on the sender(AP) card.
you can have only one wireless card if you use wireless mesh.
Good Luck.
Hi
Thanks for you input/time.
Goal:
- I want to run/have MIMO or at least 802.11 N in 5.8 Ghz as a back bone connection between my hotspots Access points.
- I want to have seperate antanna for clients.
Questions:
What miniPCI would you suggest.
What miniPCI did you used or test on 433 / AH RBoards and what covering range can my client get from the MiniPCI , and what range will my APs on the backbone connection between each other 300 ft, 1/2 Km ?? ???
Is 25Dbi for back bone miniPCI in 5.8 802.11 N, with 6 Dbi Antenna is sufficient miniPCI power? what the distance to cover am i looking at?
Sorry for so many question but i want to have this done right in 1st place.
Thank you
