Hi all,
not sure if this is the kind of very broad, open-ended question that will get tomatoes thrown at me in here (stackoverflow ptsd?) but I’ll give it a shot.
TL;DR
is this ok as a default/starting configuration?
# 2024-04-22 14:23:28 by RouterOS 7.14.3
# software id = *****
# model = CCR2004-1G-12S+2XS
# serial number = *****
add name=lan
set [ find default-name=sfp28-2 ] fec-mode=fec91
add name=LAN
add name=dhcp_pool0 ranges=192.168.100.100-192.168.100.254
add address-pool=dhcp_pool0 interface=lan name=dhcp1
/ipv6 dhcp-server
add address-pool=v6pool interface=lan name=v6server
/port
set 0 name=serial0
set 1 name=serial1
add bridge=lan interface=sfp28-1
add bridge=lan interface=sfp-sfpplus1
add bridge=lan interface=sfp-sfpplus2
add bridge=lan interface=sfp-sfpplus3
add bridge=lan interface=sfp-sfpplus4
add bridge=lan interface=sfp-sfpplus5
add bridge=lan interface=sfp-sfpplus6
add bridge=lan interface=sfp-sfpplus7
add bridge=lan interface=sfp-sfpplus8
add bridge=lan interface=sfp-sfpplus9
add bridge=lan interface=sfp-sfpplus10
add bridge=lan interface=sfp-sfpplus11
add bridge=lan interface=sfp-sfpplus12
/ipv6 settings
set accept-router-advertisements=yes
add interface=ether1 list=LAN
add interface=lan list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=\
192.168.88.0
add address=192.168.100.1/24 interface=lan network=192.168.100.0
/ip dhcp-client
add interface=sfp28-2
add address=192.168.100.0/24 gateway=192.168.100.1
/ip firewall address-list
add address=192.168.100.2-192.168.100.254 list=allowed_to_router
add address=192.168.88.2-192.168.88.254 list=allowed_to_router
add action=accept chain=input comment="Established, Related" \
add action=accept chain=input comment=icmp protocol=icmp
add action=accept chain=input comment="Allowed local subnets" \
src-address-list=allowed_to_router
add action=drop chain=input
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment="Established, Related, Untracked" \
add action=accept chain=forward comment="Traffic out" out-interface=sfp28-2
add action=accept chain=forward comment=dstnat connection-nat-state=dstnat
add action=drop chain=forward comment="Drop everything else"
add action=masquerade chain=srcnat out-interface=sfp28-2
add action=masquerade chain=srcnat comment="hairpin (lo nat)" dst-address=\
!192.168.100.1 src-address=192.168.100.0/24
add action=dst-nat chain=dstnat comment=WebServer dst-address=!192.168.100.1 \
dst-address-type=local dst-port=80,443 protocol=tcp to-addresses=\
192.168.100.2
add action=dst-nat chain=dstnat comment="Minecraft TCP" dst-address=\
!192.168.100.1 dst-address-type=local dst-port=25565 protocol=tcp \
to-addresses=192.168.100.2 to-ports=25565
add action=dst-nat chain=dstnat comment="Minecraft UDP" dst-address=\
!192.168.100.1 dst-address-type=local dst-port=25565 protocol=udp \
add disabled=no distance=1 dst-address=192.168.2.0/24 gateway=192.168.100.2 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet address=192.168.100.0/24 disabled=yes
set ftp address=192.168.100.0/24 disabled=yes
set www address=192.168.100.0/24 disabled=yes
set ssh address=192.168.100.0/24 port=65535
set www-ssl address=192.168.100.0/24
set api address=192.168.100.0/24 disabled=yes
set winbox address=192.168.100.0/24
set api-ssl address=192.168.100.0/24 disabled=yes
/ipv6 address
add from-pool=v6pool interface=lan
/ipv6 dhcp-client
add add-default-route=yes interface=sfp28-2 pool-name=v6pool \
pool-prefix-length=56 request=address,prefix
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=forward comment="init7 default" connection-state=\
established,related disabled=yes in-interface=sfp28-2 out-interface=lan
add action=drop chain=forward comment="init7 default" disabled=yes \
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
add action=drop chain=input comment="drop everything not coming from LAN" \
in-interface=!lan
connection-state=invalid
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface=!lan
/ipv6 nd
set [ find default=yes ] interface=lan managed-address-configuration=yes mtu=\
1500 other-configuration=yes
/system clock
set time-zone-name=Europe/Zurich
/system health settings
set fan-min-speed-percent=0%
/system note
set show-at-login=no
/system package update
set channel=testing
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
I’m just setting up my first Mikrotik router. CCR2004-1G-12S+2XS
The starting configuration came from my new ISP (init7, Switzerland).
They shared a conf file in their setup quick guide: https://www.init7.net/de/support/routerinfos/2023_anleitung_mikrotik_fiber7_de_en_fr_02.pdf (English starts on page 3)
Then I took a look at:
- https://tangentsoft.com/mikrotik/wiki?name=Default%20Router%20Configuration
- https://help.mikrotik.com/docs/display/ROS/Building+Your+First+Firewall#BuildingYourFirstFirewall-IPv6firewall
- https://gist.github.com/ebababi/edad2fcc586961ae55b24686974176ad
And i tried to cherry-pick rules that weren’t already in my starting conf.
The ipv6 worries me the most, since that’s still pretty much rocket science for me. I’m very much clueless about it, but my ISP gives me a static ipv6 /48 subnet with my subscription, so I guess it’s time to start looking into it.
With my previous ISP (Swisscom, Switzerland) I had a very simple/dumb proprietary router they gave me with their fiber subscription.
So for my lab subnet I had a pfSense in dual NAT. I have that already configured and working, so I left it on for now and I just hooked it up to this new Mikrotik.
Because of that, I’m not too worried about basic hardening rules, since I (should) have those covered in my pfSense setup.
Still, I’m planning to eventually drop the dual NAT, and would be nice to not have a complete mess in RouterOS when that happens.
Thanks for the help, and if this kind of “here, you sort it out for me” questions are not OK in this forum, I apologize. Let me know and I’ll delete this thread.
