Is my firewall config up-to-date with current IETF spec (IPv4 & IPv6)?
EDIT: I have updated my post with new rules/changes based on the input I received here: https://www.reddit.com/r/mikrotik/comments/ld390x/is_my_firewall_config_uptodate_with_current_ietf/
So I referenced from MikroTik’s new 2020 dated documentation domain/site and built the IPv4 and IPv6 firewall from scratch + I also read up on some RFCs (IPv4 only as of now with some general idea on IPv6 as it’s too complex for me at the present) and build the firewall which I believe is fully IETF complaint and matches with 2021 current networking practices.
Also, I took advantage of the “Firewall RAW” feature offered on MikroTik.
MikroTik sources:
TL;DR I’d like some expert opinion on the overall firewall-config plus my ICMP “RAW vs Filter” concern above to ensure it’s as per current best networking practices.
IPv4 Firewall
Neatly commented/formatted each rule to explain their purpose including disabled rules.
I disabled “224.0.0.0/4” in bad_dst_ipv4 as I use multi-cast routing.
add action=accept chain=input comment="defconf: accept ICMP after RAW" protocol=icmp
add action=drop chain=input comment="defconf: drop all not coming from LAN's interface list/subnets" in-interface-list=!LAN
add action=drop chain=forward comment="Drop tries to reach not public addresses from LAN" dst-address-list=not_in_internet in-interface-list=LAN out-interface-list=WAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=jump chain=forward comment="Jump to DDoS detection" connection-state=new in-interface-list=WAN jump-target=detect-ddos
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s protocol=tcp tcp-flags=syn,ack
add action=add-dst-to-address-list address-list=ddos-targets address-list-timeout=10m chain=detect-ddos
add action=add-src-to-address-list address-list=ddos-attackers address-list-timeout=10m chain=detect-ddos
/ip firewall raw
add action=drop chain=prerouting dst-address-list=ddos-targets src-address-list=ddos-attackers
add action=accept chain=prerouting comment="defconf: accept DHCP discover" dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment="defconf: drop bad src IPs" src-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bad dst IPs" dst-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bad src IPs" src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment="defconf: drop bad dst IPs" dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_in_internet
add action=drop chain=prerouting comment="defconf: drop forward to local lan from WAN" dst-address-list=lan_subnets in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop local if not from default IP range" in-interface-list=LAN src-address-list=!lan_subnets
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 protocol=udp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" jump-target=icmp protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" jump-target=bad_tcp protocol=tcp
add action=accept chain=prerouting comment="defconf: accept everything else from LAN" in-interface-list=LAN
add action=accept chain=prerouting comment="defconf: accept everything else from WAN" in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=accept chain=icmp comment="defconf: echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=icmp comment="defconf: net unreachable" icmp-options=3:0 protocol=icmp
add action=accept chain=icmp comment="defconf: host unreachable" icmp-options=3:1 protocol=icmp
add action=accept chain=icmp comment="defconf: protocol unreachable" icmp-options=3:2 protocol=icmp
add action=accept chain=icmp comment="defconf: port unreachable" icmp-options=3:3 protocol=icmp
add action=accept chain=icmp comment="defconf: host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="defconf: echo request" icmp-options=8:0 protocol=icmp
add action=accept chain=icmp comment="defconf: time exceeded " icmp-options=11:0-255 protocol=icmp
add action=accept chain=icmp comment="defconf: allow parameter bad" icmp-options=12:0 protocol=icmp
add action=drop chain=icmp comment="defconf: drop other icmp" protocol=icmp
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" port=0 protocol=tcp
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
#Disabled as my ISP uses this very subnet on their access concentrator
add address=10.0.0.0/8 comment=RFC6890 disabled=yes list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=not_in_internet
add address=255.255.255.255 comment=RFC6890 list=not_in_internet
add list=ddos-attackers
add list=ddos-targets
#My LAN subnets
add address=192.168.80.0/24 comment="LAN subnets" list=lan_subnets
add address=192.168.81.0/30 comment="LAN subnets" list=lan_subnets
add address=192.168.82.0/31 comment="LAN subnets" list=lan_subnets
add address=127.0.0.0/8 comment="RAW Filtering - RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="RAW Filtering - RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="RAW Filtering - RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="RAW Filtering - RFC6890 documentation" list=bad_ipv4
add address=203.0.113.0/24 comment="RAW Filtering - RFC6890 documentation" list=bad_ipv4
add address=240.0.0.0/4 comment="RAW Filtering - RFC6890 reserved" list=bad_ipv4
#Disabled as I use Multicast routing
add address=224.0.0.0/4 comment="RAW Filtering - multicast" disabled=yes list=bad_src_ipv4
add address=255.255.255.255 comment="RAW Filtering - RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="RAW Filtering - RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="RAW Filtering - RFC6890" disabled=yes list=bad_dst_ipv4
IPv6 Firewall
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=drop chain=input comment=dropLocalLink_from_public in-interface=pppoe-out1 src-address=fe80::/16
add action=accept chain=input comment="allow allowed addresses" src-address-list=allowed
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop bad forward IPs" src-address-list=no_forward_ipv6
add action=drop chain=forward comment="defconf: drop bad forward IPs" dst-address-list=no_forward_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="local clients to public" in-interface=!pppoe-out1 src-address-list=allowed
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 firewall raw
add action=accept chain=prerouting comment="defconf: enable for transparent firewall" disabled=yes
add action=drop chain=prerouting comment="defconf: drop bad src IPs" src-address-list=bad_ipv6
add action=drop chain=prerouting comment="defconf: drop bad dst IPs" dst-address-list=bad_ipv6
add action=drop chain=prerouting comment="defconf: drop packets with bad src ipv6" src-address-list=bad_src_ipv6
add action=drop chain=prerouting comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_dst_ipv6
add action=drop chain=prerouting comment="defconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv6
add action=accept chain=prerouting comment="defconf: accept local multicast scope" dst-address=ff02::/16
add action=drop chain=prerouting comment="defconf: drop other multicast destinations" dst-address=ff00::/8
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=fd12:672e:6f65:8899::/64 list=allowed
add address=fe80::/16 list=allowed
add address=ff02::/16 comment=multicast list=allowed
add address=2001::/23 comment="defconf: RFC6890" list=bad_ipv6
add address=100::/64 comment="RAW Filtering - RFC6890 Discard-only" list=not_global_ipv6
add address=2001::/32 comment="RAW Filtering - RFC6890 TEREDO" list=not_global_ipv6
add address=2001:2::/48 comment="RAW Filtering - RFC6890 Benchmark" list=not_global_ipv6
add address=fc00::/7 comment="RAW Filtering - RFC6890 Unique-Local" list=not_global_ipv6
add address=::/128 comment="RAW Filtering" list=bad_src_ipv6
add address=ff00::/8 comment="RAW Filtering" list=bad_src_ipv6
add address=::/128 comment="RAW Filtering" list=bad_dst_ipv6
add address=fe80::/10 comment="defconf: RFC6890 Linked-Scoped Unicast" list=no_forward_ipv6
add address=ff00::/8 comment="defconf: multicast" list=no_forward_ipv6
Reddit thread here: https://www.reddit.com/r/mikrotik/comments/ld390x/is_my_firewall_config_uptodate_with_current_ietf/
