I have an old hAP ac that I use for ~7 years. My setup is basic:
ISP (300/40Mbit/s) --- DHCP -> | hAP ac | ----> LAN
I never payed too much attention to my down/up speed as I’m not a heavy downloader and in 99% of the time internet just works. But recently I started investigating why I cannot download big files faster than 10-15MB/s. To rule our my config, which might be wrong due to VLANs I reverted hAP ac to factory config and connected it directly to my computer for tests. So the setup is:
ISP -> eth1 - hAP ac -> 1Gbit/s LAN - Computer
Unfortunately I’m still getting 10-15MB/s down for big files. Also I’m using iperf3 with https://proof.ovh.net/ and my speeds rarely exceed 200Mbit/s. The CPU during download have spikes to 20% rarely 30%. Temperature is around 50*C. I tried also to use sfp port instead of eth1 but the speeds are the same. I observed that downloading small files is not a problem and I can reach 25-27MB/s on them. Also downloading games from steam saturates my download without issues. The problem is only with iperf/big files.
I also have CRS310-8G+2S+IN so I configured it as a router with NAT enabled and also fasttrack and I’m able to hit 300Mbit/s on OVH iperf and files download with ~35MB/s
Am I missing something or my hAP ac is just starting to have hardware issues?
For file download: https://proof.ovh.net/files/10Gb.dat
Also iperf3 -c proof.ovh.net -p 5206 -R (port is random, sometimes it rejects the 5206)
What do you mean test multiple files? Also what logs? In hAP logs I don’t see anything suspicious.
What if you start multiple downloads, is the combined speed higher?
iperf3 -c proof.ovh.net -p 5206 -R -P 8 (gets you 8 streams), does that make a difference?
As the hAP ac is single core, that is not the limiting factor.
What is the hAP ac connected to?
