Is my route well configured?
i successfully configured Zerotier VPN, and from my Mikrotik router, i’m now able to access remote LAN, from any of my VLAN.
Let’s take the example that :
  • The IP of Mikrotik on Zerotier interface is 192.168.200.254
  • The remote LAN (reachable through ZT) 192.168.1.0/24
and the routing is configured like that:
add gateway=192.168.200.254
add dst-address=192.168.1.0/24 gateway=192.168.200.20
So, far so good, it’s working i can reach remote LAN.
However, if i look on the ARP table, i’m surprised to see that the remote 192.168.1.1 IP appears for any of my VLAN.
Is that the normal behaviour? Or is there somethign worng with my config?
Thank you for your help
