Is my Serial Console enabled and switched on?
Hi all,
I have a CRS328-24P-4S+RM, and have it’s serial console plugged in. The serial console does not respond. Other serial consoles work on other devices, so we know the client side works fine. We have tried different cables, introducing null modem cables, nothing works.
The question is, given this configuration, is the serial console enabled and switched on?
[minfrin@router] /system console> print
Flags: X - disabled, U - used, F - free
 #   PORT        TERM
 0 F serial0        vt102
There is a flag called F for “free”. What does “free” mean? There is another option called “used”. What does “used” mean in this context.
If I can eliminate “configured wrong”, and I can send this router in for repair.
Regards,
Graham
Quick test says that “used” is when there’s user logged in on that console.
Also check that port is configured correctly in system/ports. You can also try no handshaking as some boards only connect RX/TX and nothing else.
