IS Nv2 Compatible with x86 mikrotik routers
Hello uys,
When RouterOS v5 came out, there was no support for Nv2 on x86 system.
Is it still that way?
I just saw it IS NOT :slight_smile:
It works, but on RouterBOARD it works better, because we have full hardware control, whereas each PC is slightly different.
so i can test it on my own risk?
coz on 4.17 the wireless link disconnects from time to time (only 1 end is PC, other is 435GL).
I mean, the feature is there but you cvan not guarantee if it is going to work perfectly?
I am willing to test it becouse it does not work the right way at the moment…so maybe i have nothing to lose :wink:
yes, stability will depend on the motherboard and some other unknown factors. maybe it works better in v5.14
