Is RB Metal2-SHPn very cheaper than RB 711UA-2HnD ?
I have some AP built with RB 711UA-2HnD.
A Ap is broken and I replaced it with an RB Metal2-SHPn.
The signal emitted by RB Metal2-SHPn is much weaker.
I have also tried to replace the RB Metal2-SHPn with a new but it doesn’t change.
Why?
Should not be stronger considering that RB Metal2-SHPn has a power of 31 dBm while RB 711UA-2HnD has a power of up to 27 dBm?
It should be a lot stronger because Rb711 also loose some power in the pigtails.
Ok, and as I can resolve?
can there be some parameter to modify?
The Antenna gain is also to 0 dBi as in the RB711…
I’m really disappointed by these Metal2-SHPn.
I’ve changed one with a RB951UI-2HND and this works much better!
Maybe something wrong in the configuration?
Perhaps Metal2-SHPn is an obsolete product?
applying the correct confguration can do wonders, read this experience with the same product:
http://forum.mikrotik.com/t/2-4ghz-metal-radio-blown-after-30-secs-of-traffic/68853/3
Ok well, I’m applying this configuration (model 2)
http://wiki.mikrotik.com/wiki/Wireless_WDS_Mesh
Do you think it works for RB Metal2-SHPn ?
like wirelessrudy suggested in the other topic, make a “/interface wireless reset-configuration”, then start from the beginning, if still have problems, paste both end wireless export outputs here
I HAVE ALREADY DONE: system reset-configuration skip-backup=yes no-defaults=yes, BUT DOES NOT WORK.
I have attached the file .rsc of the RB connected in LAN.
The other RB are configured identically, only changes the IP address, can’ t reach them with telnet…
aug/22/2013 10:17:12 by RouterOS 5.25
software id = UL77-FDT0
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500
name=bridge1 priority=0x8000 protocol-mode=rstp transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1598
mac-address=D4:CA:6D:7B:09:02 mtu=1500 name=ether1 speed=100Mbps
set [ find default=yes ] authentication-types=“” eap-methods=passthrough
group-ciphers=aes-ccm group-key-update=5m interim-update=0s
management-protection=disabled management-protection-key=“” mode=none
name=default radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“”
static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=
“” wpa2-pre-shared-key=“”
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=5 area=“”
arp=enabled band=2ghz-b/g/n basic-rates-a/g=6Mbps basic-rates-b=1Mbps
bridge-mode=enabled channel-width=20mhz compression=no country=italy
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=
0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=
no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=2412
frequency-mode=regulatory-domain frequency-offset=0 hide-ssid=no
ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-guard-interval=any ht-rxchains=0 ht-supported-mcs=“mcs-0,mcs-1,mcs-2,mc
s-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14
,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23”
ht-txchains=0 hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=
D4:CA:6D:7B:09:03 max-station-count=2007 mode=ap-bridge mtu=1500
multicast-helper=default name=wlan1 noise-floor-threshold=default
nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key=“”
nv2-qos=default nv2-queue-count=2 nv2-security=disabled
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name=RADIOMAR-AP1
rate-selection=advanced rate-set=default scan-list=default
security-profile=default ssid=WIFI-MARELAGO station-bridge-clone-mac=
00:00:00:00:00:00 supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
bridge1 wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic-mesh
wireless-protocol=any wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:
17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H
T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-
7:17”
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
3200 framer-policy=none
/ip hotspot profile
set [ find default=yes ] dns-name=“” hotspot-address=0.0.0.0 html-directory=
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=
cookie,http-chap name=default rate-limit=“” smtp-server=0.0.0.0
split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default
use-compression=default use-encryption=yes use-mpls=default
use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=
ospf-in metric-bgp=auto metric-connected=20 metric-default=1
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,w
eb,sniff,sensitive,api,!ftp,!write,!policy” skin=default
set write name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,pa
ssword,web,sniff,sensitive,api,!ftp,!policy” skin=default
set full name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,
winbox,password,web,sniff,sensitive,api” skin=default
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none
interface=ether1 path-cost=10 point-to-point=auto priority=0x80
interface=wlan1 path-cost=10 point-to-point=auto priority=0x80
interface=wds4 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=
1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:E5:94:1F:8E:CF
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.5.50.90/22 disabled=no interface=bridge1 network=10.5.48.0
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=4096 servers=“”
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 disabled=no
set wlan1 disabled=no
set bridge1 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=
no src-address=0.0.0.0
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
10.5.50.1 scope=30 target-scope=10
/ip service
set telnet address=“” disabled=no port=23
set ftp address=“” disabled=no port=21
set www address=“” disabled=no port=80
set ssh address=“” disabled=no port=22
set www-ssl address=“” certificate=none disabled=yes port=443
set api address=“” disabled=yes port=8728
set winbox address=“” disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment=“default share” directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password=“” read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=only-hardware-queue
set wlan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-generators=“”
trap-target=“” trap-version=1
/system clock
set time-zone-name=Europe/Rome
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system identity
set name=CAMPING1
/system leds
set 0 disabled=no interface=wlan1 leds=led1,led2,led3,led4,led5 type=
wireless-signal-strength
set 1 disabled=no interface=ether1 leds=user-led type=interface-activity
/system logging
set 0 action=memory disabled=no prefix=“” topics=info
set 1 action=memory disabled=no prefix=“” topics=error
set 2 action=memory disabled=no prefix=“” topics=warning
set 3 action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=10.6.50.61 secondary-ntp=10.6.50.1
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=
400MHz force-backup-booter=no silent-boot=no
/system scheduler
add comment=“reboot notturno” disabled=no interval=1d name=“reboot notturno”
on-event=“/system reboot” policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api
start-date=aug/18/2013 start-time=04:00:00
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 starttls=no user=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no secret=“”
/tool sniffer
set file-limit=1000KiB file-name=“” filter-ip-address=“” filter-ip-protocol=
“” filter-mac-address=“” filter-mac-protocol=“” filter-port=“”
filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups=“” interim-update=0s
use-radius=no
2SHPN_MeshModel2_bridge_interface_CAMPING1.rsc (15.5 KB)
Start by upgrading to RouterOS v6.2, you are using an old version. v6 has new drivers, new kernel, new wireless functionality etc.
Ok but the configuration is correct?
For example: when I try to connect to a RB that I see in the table neighbors this error appears :
Trying 10.5.50.93…
telnet: Unable to connect to remote host: No route to host
What does it mean?
can you ping or mac-ping that device?
No, I see the RB D4:CA:6D:7B:08:BF in Scanner of wlan1
I see The RB in Neighbor Table ( IP: 10.5.50.93 )
Ping: Host: 10.5.50.1 / Time: 0ms / Reply Size: 78 / TTL:64 / Status: redirect host
Host: 10.5.50.93 / Time: timeout / Status: timeout
Mac Ping: To: D4:CA:6D:7B:08:BF : Time: timeou / Status: timeout
What can I do?
contact support@mikrotik.com with support file attached - make sure you are upgraded to v6.2
I contacted the support. But I had a configuration problem and advised me to install Netinstall.
I installed Netinstall on a notebook.
On the ethernet port of the notebook I connected the Metal 2SHPN
In the USB port of noteb I inserted a flash memory
Launch the program netinstall.exe and find the removable media Label E:
The notebook has ip 192.168.27.6 \ netmask: 255.255.255.0 \ Gateway:
192.167.27.1
How to address Net booting I put 192.168.27.5
In the Packages \ From field, with Browse, I select the file :
routeros-mipsbe-6.2.npk but he does not see in the box below
If I press Insall this alert appears: No Select Packages
What can I do?
First select the router, only then select browse for packages. In this order.
but even before that, you must start the Metal with the button pressed, to launch Netinstall boot mode. Then do the above, in mentioned order.
Worked!
Thank you very much
can you help me for the problem WDS-MESH?
I wrote to support but I did not respond, unfortunately, is a pressing issue …
The last thing I wrote was this :
since you are using the IP address on the bridge interface, we suggest to
lock the
MAC address to the wireless or ethernet interface that is added to the
bridge
ports.
Could you make a diagram and send it to us and also the support output
files from
both routers?
Also we recommend to add WDS interfaces into the bridge port statically
and not
dynamic to avoid wds flood.
I tried to run the command:
interface bridge set bridge1 auto-mac=no admin-mac=XX:XX:XX:XX:XX:XX
and it works, the interface bridge1 assumes the MAC of interfaces wlan1 but
I lose the ability to connect via the IP
of interface ether1 .
This is necessary because the RB are connected to an ethernet port of a
TB1100 ( with IP 10.5.50.1 ) while WinBox is installed
on a lan 192.168.27.x to one other port of RB110 ( with IP 192.168.27.181 )
How can I fix?
have gone ahead..
I would like to set, as recommended, wds connection manually and not automatically.
I know the MAC address of RB that are connected.
The field WDS mode I must put in static?
