is RB153 stable with 3 r52's now?
Hello
I read about problems with rb153 and rebooting problem.
If I have latest ros + firmware will rb153 be stable for me?
I have 3 i’d like to deploy but want to check first
the 3 minipci is great for 1 backhaul and 2 sectors :wink:
Are you sure you’ll have enough CPU to put a reasonable number of clients on?
Hello
The plan was to have a cheap solution on a new station and see how it goes
If I get more then 20 clients I’ll go for 2 rb500’s :slight_smile:
I also like sectors better, even if only for the range and less interference
Thanks, Its something to think about.
