Is RB962UiGS-5HacT2HnT faulty?
I am thinking about buying RB962UiGS-5HacT2HnT but I read in previous threads that they had some faulty series and when using wifi+LAN it makes huge problems. May you please confirm whether this problem is still present? My local biggest shop took this product down and they do not offer it anymore - that’s why I am just curious if is this problem solved in new series? Thank you.
That is the hAP ac. It is an excellent product and works great. It is actually our best indoor WiFI AP right now.
Not sure what you mean about distributor taking it down, most likely they simply ran out of stock and it will be back soon. Better ask them directly.
I found it on ebay, but the date of the router is 10th April 2016. Should I buy a newer one or this problem was resolved with firmware? I mean all these issues: http://forum.mikrotik.com/t/is-hap-ac-stable-now/111071/1
Thank you for quick reply.
I want to know then same, @normis pls update us, if problem with slow speeds (WAN-LAN) and temperature are fixed in newer production batch.
