Is "Reselect channel" gone in WiFi?
In a couple of Capsman v2 setups I did, two APs were put on same 5GHz frequency which is not what I wanted.
I know I can set a ‘reselect interval’, and I can manually set a frequency, but what has happened to ‘Reselect channel’ button which causes the auto-select to try again? Must I instead disable and re-enable the interface?
I start the scan process for the radio to trigger the reselect. AFAIK, besides disable/enable there is no other trigger.
In my experience (v7.19.6), although I set reselect-time during the night, the accesspoints tend to select equal frequencies. Hence I set frequencies manually.
Thanks. Yes I usually select manually. but to begin with I will let it select automatically, and if I see two on same channel close-by, it would be nice to just click 'reselect'. I don't know why they got rid of that button!
