Good day, i configured a freeradius 2 server, and is running fine and tested with daloradius, radclient, and radlogin.
But when i activate radius on my RB1100, start the hotspot, and try login in the browser, the radius mechanism fail. The freeradius server dont see nothing, zero request from the routerboard.
You can help me please? What is my error? I am sending the export of configuration, if someone see the error please help me.
Thanks!!!
/log print
17:11:05 hotspot,info,debug carlos.caicedo (172.16.2.127): trying to log in by http-chap
17:11:05 radius,debug new request 3f:28 code=Access-Request service=hotspot called-id=hotspot1
17:11:05 radius,debug timeout for 3f:28
17:11:07 hotspot,info,debug carlos.caicedo (172.16.2.127): login failed: RADIUS server is not responding
jan/19/2012 17:00:50 by RouterOS 5.8
software id = XXXX-XXXX
/radius
add accounting-backup=yes accounting-port=1813 address=172.16.2.10 authentication-port=1812 called-id=“” disabled=no domain=“” realm=“” secret=secret service=hotspot timeout=3s
/radius incoming
set accept=yes port=3799
/ip hotspot profile
set default dns-name=“” hotspot-address=172.16.2.3 html-directory=hotspot http-cookie-lifetime=3d http-proxy=127.0.0.1:31280 login-by=cookie,http-chap name=default nas-port-type=ethernet
radius-accounting=yes radius-default-domain=“” radius-interim-update=received radius-location-id=“” radius-location-name=“” radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit=“”
smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
add dns-name=“” hotspot-address=172.16.2.3 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=hsprof1 nas-port-type=ethernet
/ip hotspot
add disabled=yes idle-timeout=5m interface=ether1 keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default name=default shared-users=unlimited status-autorefresh=1m transparent-proxy=no
add advertise=no name=oficina open-status-page=http-login rate-limit=128k/256k shared-users=unlimited status-autorefresh=1m transparent-proxy=yes
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add disabled=no name=admin password=xxxxxxxx profile=default
/ip hotspot walled-garden
add action=allow comment=“place hotspot rules here” disabled=yes
/ip hotspot walled-garden ip
add action=accept disabled=no dst-address=172.16.0.0/16 src-address=172.16.0.0/16
