I was curious if anyone has used or knows if the Telite LM960 is compatible with any of the current RouterBOARD hardware.I have been eyeing using the RBM33G and the Telite LM960.
Thank you for your time and input!
Hello, I’m also interested on a that modem from Telit. Did you already contact the MikroTikˋs support?
Kind regards
I have not contacted their support yet but I did go ahead and order that RouterBOARD from Mikrotik. I will let you know if I can get it to work.
Trying to get it to work on a Mikrotik RouterBOARD 912UAG-5HPnD today but so far no luck, it is not detecting the modem.
Hello, I am testing a telit lm960 card with a LHG-LTE-KIT-US but mikrotik does not recognize the lm960, someone knows if it is compatible
Did you try putting it in USB 2.0 mode?
how is it done? what do you mean?
