Is the cAP ac a passive PoE or an active one?
Specifically, can the injector be used with non-PoE products or will it damage them? I can’t find any specifications anywhere other than the voltage range (18-57V)
Thanks!
The unit accepts both 802.3af/at and Passive PoE on input, but only provides Passive PoE on output. The injector that ships with the unit is Passive only.
