Is the script will auto run itself or we need scheduler?
Good day…
Dear Buddy..
below is the script i got from mikrotik to check the port flapping.
Need you sharing that, where should i put the script? and how the script will run?
:global lastRate;
/interface ethernet monitor ether1 once do={
:if ($status = “link-ok”) do={
:if ($lastRate != $rate) do={
:set lastRate $rate
:put “send email here”
} else={
:put “status not changed”
do i need to put it into the scheduler to make it run every 10 minutes? or where should i put this script and how it can auto run.
i was ask google how the mikrotik script work, but since google brother is busy and given no answer to me… :sunglasses:
appreciated it..
Hello Vincent,
It is best to run this script with scheduler http://wiki.mikrotik.com/wiki/Manual:System/Scheduler
Hi Kirshteins..
I try to make this..
:global lastRate;
:set lastRate $rate
:put “/tool e-mail send server=202.133.97.7 port=25 to=bt.ang@mykris.net from=iGate_alert@mykris.net subject=”$[/system identity get name] $[/system clock get time] $[/system clock get date]" body=“The Ethernet Port mode is changed, Please check syslog for future investigation and take neccessary action”
} else={
But it’s not working, it shown me…some error on the Subject.
When i test with /tool e-mail send server=202.133.97.7 port=25 to=bt.ang@mykris.net from=iGate_alert@mykris.net subject=“$[/system identity get name] $[/system clock get time] $[/system clock get date]” body=“The Ethernet Port mode is changed, Please check syslog for future investigation and take neccessary action” it’s working and i can receive the send mail message.
where could be wrong?
appreciated for the infor.
