is there a dude package RB433UL ROS v6.39.2
I couldnt find a clear answer on my question, that is: Can I use Dude on a RB433UL ROS v6.39.2 ?
There is no package included in the extra packages. Is there one planed in the future?
Only I have found that others are still using the dude-3.6 package. Is it advisable to install it? What can happen in the worst case? Can I brick my RB433?
No. Probably not. No. Installation should be refused. Yes, you always can.
Check this.
https://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Installation#System_requirements_for_server_package
Thank you,
now I’ve dared to try it. And yes confirmed, ROS refuses to install dude-3.6 mipsbe.
Log message: …system 3.6 is not installed, but is required
cheers
