is there a possibility to flash an antenna?
hi guys
i have problems with one specific antenna in my environment. it started to malfunction and to become unstable. we tried to downgrade from 7.14 to 7.12 and even 6.49 but it simply does not downgrade.
after copying the appropiate file and executing the command /system/package/downgrade the antenna reboots and 7.14 is still installed. dont have the problem with other antennas in my environment. same problem with config restore: after restoring and rebooting the restored config is not applied and i still have my orginal state
i presume something wrong is with the antenna itself. is there any possiblity to complete wipe the flash and reinstall the routeros from scratch? not just an up- or downgrade but a “real” new reinstall including erasing the memory. any ideas?
Yes, use Netinstall https://help.mikrotik.com/docs/display/ROS/Netinstall
