Is there a way for hotspot users to print work to a printer?
Is there a way for hotspot users to print their work to a printer. A print server can be added to the printer with a static IP address and connected to the hotspot network. How would I set that up and allow users to see the printer?
I would set up a JetDirect via IP.
You will need to make drivers available via http or similar.
Just my 2bits worth.
Craig
Would you suggest doing the following:
On the main login page add a link with info on how to print and setup the printer and links to drivers for 98/ME/2000/XP/2003.
But once the user logs in, he cannot see the printer info page anymore.
Oliver
I would make the page avail ONLY AFTER they login.
Then make it available to them whenever they want.
Craig
How would I do that? Currently, after the user logs in, he is redirected to his default web site. Also, is there a way of adding a virtual printer without having the user install the printer and drivers? A way of having it all done automatically.
Oliver
