Is there a way to continuously connect snooper station data?
When using snooper, the “stations” mode allows you to see the signal strength of stations that aren’t associated with your AP. Is there a way to leave a radio in snooper mode & monitor the data remotely, using SNMP or such? I can write the SSH parser if needed, but if there’s an easier way to get data, I’d appreciate info on it.
-=Russ=-
If your in snooping or scan mode don’t all current associations get put on hold because it can’t do both at once? Are you thinking of using a second card thats always in snoop mode ?
I don’t know your answer but I wasn’t sure if you knew the above info.
Sam
Yes, I’m aware of that. There would be a separate card, or possibly even separate nodes for the continuous snooping.
-=Russ=-
