Basically in topic. I’m wondering if there is a way to do basic logging of address visited by one interface ? Specifically WLAN to find out what people are visiting.
I’m assuming that I’d have to go as far as capturing the packets with wireshark and packet sniffing on the router ?
Second part,
I’m showing 5.26 as the version and no upgrade when checking for upgrades. Is there really a reason I’d want to go to 6.X ? Are they stable ? Do I need to do anything special to upgrade ? Would need to upgrade if everything is fine with 5.26 and stable ? (Another words, will 5.26 have “security updates” ?)
For logging, you could use torch for real-time info, or put a firewall rule on the wifi interface with a target of LOG and stash that somewhere (hopefully not on your flash!) with syslog, or use netflow export, or do the sniffing thing… and probably about half a dozen more.
5.26 is at the end of development and that apparently includes security. FWIW I went from 5.26 to 6.20 on my 751G, no problem at all. Specifically the new PPP tweaks finally got me to make the switch.
Just go grab the right file, upload it to the router, reboot… easy! There’s a firmware upgrade that you can do after the OS upgrade (from system/routerboard) that comes bundled with the OS package.
