I would like to know how long it takes to fetch a URL. Is there a way to do so within a script?
unless you do it at the turn of midnight, if you memorize the time before the download and compare it with the time after the download…
How about using :timestamp? While Mikrotik doesn’t support dates or floats, they do have “time” and “time difference” type… Super useful here.
:local start [:timestamp]
/tool/fetch url="https://wttr.in/Riga+LV?T&format=2" output=user
:local stop [:timestamp]
:put ($stop-$start)
Which takes 3.1 seconds (or “00:00:03.103317400”), and we knows it’s -2C & breezy in Riga, Latvia.
status: finished
downloaded: 0K
data: -2 C 20km/h
00:00:03.103317400
Note: In theory, you might not want to use “output=user”, and use “output=none” to time it. The output to display a relatively large amount of some time. In fact almost 2 second to write to terminal. And if you normally write to disk, timing it it that way be most accurate (output=file).
{ :local start [:timestamp]; /tool/fetch url="https://wttr.in/Riga+LV?T&format=2" output=none; :local stop [:timestamp]; :put ($stop-$start)}
status: finished
downloaded: 0KiBC-z pause]
total: 0KiB
duration: 0s
00:00:01.099018660
