I am trying to simulate what the slate 7 does and have my Mikrotik act as a repeater for when I am out in hotels, etc.
I’ve noticed that the slave interface won’t broadcast in AP mode unless the master (station) is connected. Is there currently a way to get around this? Or would I basically need a script that will change the master interface to AP, etc?
I’ve tried switching the master / slave roles, where the slave is the station and master is the AP. But I don’t think that works because from what I understand the slaves operates on the same channel on the master and that’s decided when the master is running.
I was hoping there was an option for the slave (AP mode) to run on the previous channel that the master (Station) was using if the master isn’t connecting to anything.
I think the older wireless has a “skip-run-check” or something along those lines but nothing for WiFi.
You are correct, on old wireless there was indeed skip-running-check (or whatever it was called).
But it's also there for wifi: disable-running-check(no | yes; default: no )
yes - interface's running property will be true whenever the interface is not disabled
no - interface's running property will only be true when it has established a link to another device
Since you have 2 radios, why not use 1 radio for each function then ?
Isn't that easier ?
Only as a side-side note, the hap Ax 3 seems not very suitable/convenient as a travel router, besides the size It should outperform any hotel wifi speed, both 2.4 and 5 GHz, so there should be no penalty using the 2.4 as station (pseudobridge) and the 5 GHz as AP.
You are correct! I tried searching for it in WinBox but was not able to find the setting, checking the cli it does show up. I am pretty sure that should fix what I am trying to do.
It likely would be easier the way you described, I am just planning on situations where maybe one band is congested to the point of being unusable. Thank you for the help btw, that is my fault for missing it in the documentation.
@jaclaz You are correct, hap AX3 is inconvenient for my use case, I am hoping the hAP BE3 may be a little better? But I am also hoping Mikrotik will eventually update their mAP series with dual band for a little more usability on the go.
Reason I am asking in general is just for flexibility. Reason is because I live in an an apartment where most of my neighbors have their routers configured to blast out 40mhz channel width on the 2.4. Anytime my stations roam to the 2.4 it’s almost unable if I am not directly in front of it. (Plenty of retransmissions)
Obviously everywhere I go will not be like this, I just don’t want to take the chance if I have my family relying on me haha.
Just recently bought the mAP and pre-ordered the hAP BE3 Media to toy around with for this.
Yep, but the hap be3 Is still "huge" as a travel router, besides being - at least on paper - way too fast for that use.
A wap Ax would seem to me more suitable.
Neat, though a hAP ax2 has a slightly smaller volume than the wAP ax. Form factors are different. Both are too powerful though I use an ax2 if travelling with others. Alone, a mAP Lite is perfect: tiny, 5V-powered from a battery or computer USB, ethernet to the computer and WiFi station.
Yep, but the OP wants the dual band, I think that everyone is waiting for a new mAP or mAP lite (even if not Ax and even if slightly bigger) with 2.4 and 5 GHz, to be used not only as a travel router.
The mAP lite is (IMHO) even too tiny, the mAP is a "perfect" size, but even if the two radios or the heat dissipation needs would call for a larger case, I believe that everyone would be outside Mikrotik distributors shouting "Here, take my money" for it.
As a comparison the Tp-Link TL-WR902AC (AC, with two bands) is 74×67× 22mm so only a tiny bit bigger than the mAP, 68x68x19 but I am pretty sure that something up to 100x100x30 mm or so would sell like hot cakes.
Still I remain of the opinion that the slightly larger volume of the wAP Ax is "compensated" by its "soap bar" shape when compared to the hAP Ax2, but to each its own.
Personally I would prefer AX2 then over wAP AX.
A bit more practical to power plus added ether ports.
But that's me.
My road-warrior champs for now remain mAP (or mAP Lite) and AX Lite LTE (allthough for that last one the angled feet are a bit impractical, I do keep it my computer bag at all times).
I usually go to hotel with family members so we might be connecting 10 devices at a time, like phones, Nintendo switches, laptops, etc
Using the travel router as a station and masquerading your traffic would allow you to bypass captive portals for all devices. (You typically just have to agree to it once, and it would apply for all other devices)
Also, instead of every device needing to connect to the Hotel WiFi and giving out passwords, etc, all devices can connect to your travel router and then you just connect the travel router to the hotel WiFi.
Then next vacation, you connect it to the new WiFi and all your family devices will automatically connect to your travel router. Much less of a hassle.
I want to add that the skip-running-check doesn’t seem to actually work for this use case. As it stands currently it seems like it is impossible to have a slave AP broadcast if the station is not connected to an upstream AP.
This seems troublesome for something like a mAP which only has one 2.4ghz radio as it would force you to manually change the SSID for the upstream AP via a wired connection which may not be ideal for all situations.
Hopefully there is a something that can be done in the future to make MikroTik routers more travel friendly.
