Is there a way to move devices from one network map to another without having to recreate them?
Thanks,
Chadd
Thanks,
Chadd
I thought this would be an easy question for someone. Anyone know if it can or cant be done?
Thanks,
Chadd
Select the item (or items) you want to copy. Click the “copy” button (looks like two documents). Once you have copied the device the “paste” button will become active. (looks like a document on a clipboard).
Go to the map you want to duplicate the device on and click the “paste” button.
In my experience sometimes the paste button stubbornly refuses to be come active and I need to reboot. If you paste a device that has links attached to it and you don’t paste the devices at both ends of the link , the links end up detached and sitting up in the top left of the map. Select these links and then delete them.
Thanks I will give it a try.
